Problem with cold start injector
If I have it connected (multiplug on the back of the inlet manifold) my car refuses to start. Fuel pump primes ok but the starter motor doesn't even turn. Nothing. If I then disconnect the cold start injector it'll fire up with no problems at all! Any ideas?!
Yeah thats a strange one mate?! Must be some sort of wiring problem (er... obviously lol
). I'd take a look at the starter wiring first!
It starts without the cold start injector ok because your main injectors are probably leaking whilst the car is stood up and so there is plenty of fuel in there for a cold start (this is the most common reason for unpluging the cold start injector, when really the main injectors should be replaced!).
That makes sense I guess. I know my starter wiring isn't the best - the exhaust is waaay to close to the starter, I thought there was a bit more room usually but the cars got a massive s/s exhaust straight from the turbo... Might need to change that, lol
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
The Enigma
13
Aug 20, 2015 09:38 PM
Archiejay
Aug 12, 2015 12:07 PM
Zoggon
Aug 10, 2015 10:39 AM
