estimated bhp for my rs turbo
hi there people
i got an escort rs turbo s2 g reg 90 spec
gotech fuel managment system, front mounted intercooler, full scorpion stainless steel exhaust 4" rolled tip, t3 stage 2 turbo, pipercross ,vxr injectors. and baileys dv26 dump valve.....
i am takin it to the rollers to get set up again properly and would like to no wt bhp output i shud be expectin it was 182bhp with a t34 turbo bt that has been removed due to the lag
let us know how you get on mate i have similar spec to you and i quite fancy gotec it will be good to see how well it works, were you taking it ?
Friend of mine had Gotech on his rst set up at jamsport. Took a fair bit of mapping but seemed to do the job well. He got around 240bhp, not sure of his entire set up tho.
their prices start from around £140 then depending on the ammount of time they take on the set up.
They can supply and map Gotech for £750 so i guess if you already have it installed its still not going to be cheap.
so i guess its all dependant on how long it takes to tune. Correct me if im wrong but I think most places its around £60-70 an hour for rolling road
umm nt 2 sure really der will ba t3 turbo on it instead of a t34 wen i tgoes bk..... i fink its overfueling and its nt idling very wel... and seems to back fire a lot and is quite lumpy to drive
JK12
33
26-04-2021 12:09 PM
Matt Baxter
16-09-2015 08:30 PM
Rsmat
42
01-09-2015 09:39 PM
CrOwSoN15
18
22-08-2015 10:24 PM
