ERST Oil cap coming off when car is booted up??
Hay am a new owner ov a very good example White 1989 S2 Escort RS Turbo but a think am getin a but paranoyd.
My oil cap is coming off when am booting the car up can any one tell me why. Could it be that aye have no dump valve on??
Aye have bent the cap a bit so it slips on tight for time being.
focus rs 1672
But when a relized this happen the cap was off would aye ov not notice theres something wrong.
Could it be that aye need a new cap?? It did feel very lose comeing off and on??
No theres no chuffin, Would the cuffin noise be loud??
It is a aftermarket alloy rocker cover and aye think a standerd cap (Yellow) if that would make a diffrance??
The engine seems to be runnin sweet when drivein what should aye look for guys??
Make sure the pipe from the rocker cover down the back of the block, isn't... ummm blocked.
Also have a look at the breathers on the other side of the rocker cover.
Aye think it might be the oil cap gonna change it when aye give it a oil change tomorrow.
Dose all the rs turbo's oil caps just slip on???
Do u mean fit a oil breather?? Cause a have nae got one on the engine plus nore a dump valve the last owner took them off cause where the dump valve was has now been blocked off so a dont think the engine is getting to breath??
Just hope he didnt remove the dump valve to cover up ring wear as if this is the case the dump valve would of been blowing out oil, run the car up and remove the oil cap if the revs drop and it goes to stall you should be ok also check your breather pipes for blockages, if not its more than likely rings.
Right just tryed it started the car then a pulled off the oil cap nothin happened no rev change ect there was a bit off air comin out.
When a give it a rev it started to drop down to 300-400 revs and it felt like it was gonna stall??
Balls Deep!
Thats a bit of a leap mate!
There is only 2 reasons that the engine doesnt stall when the Oil filler cap is removed, either the breathers are clogged up, or the return to metering head is blocked off, doesnt indicate anything about engine condition at all!
If the engine stalls when the caps removed and it's blowing it off under load then I would say piston rings and a rebuild is needed.
Thanks mate a will defo do all that. Besides all this the engine seems to be fine. Hope this is not a big problem or harmin the engine
by the time i had read the thread and replied i missed his last reply, if he has tried it and it nearly stalled then yes i would agree possibly blocked breather, to be fair it would be my first port of call as its the cheapest option !
sorry if this has been mentioned as i havnt read the whole thread, try a compression test to see if its piston rings, if low place say a tea spoon of oil down each cylinder and test it again, if rings then should see a large increase in compression, hope this helps
focus rs 1672
for all the years ive heard check the breathers for blockages,ive never seen a blocked breather,if this car is just bought(or brought as u's like to call it) and has the dump valve removed chances are its been removed to hide oil blowin out the dump valve and stainin the bonnet,if u can check the intercooler and intercooler hoses to see if theres excess oil.to be honest mate id stop drivin g it till u get it sorted,right now worse case scenario ull need new rings,maybe a hone on the bores,keep drivin and ur riskin det and cracked pistons
Well just my luck after giving it a service oil motorsport 1 15w 50 ,oil filter, sump kit, spark plugs.
Was just two feet from my house after giving it a run for a hour or so, booted her up then pop revs drop smoke pissin out the exhaust and out the bonnet,
Opened the bonnet to see that the seal on the turbo was smokein two??
Drove it down the street tryed bootin it no turbo kickin in so looks like a need a new turbo, How much will a new one cost??
I paid £519.00 + vat (about £620 odd) exchange for a Ford Escort RS Turbo Stage 2 turbo from Turbo technics.
heres a test for you,
to find your problems are so,
Needs a rebuild, due to pistion wear or pistion crack, ring's.
- Remove the boost hose from your turbo to ur MFI fuelings, check no play in your turbo, then replace all, thats to just check if your turbo is all ok. next start up the car and leave it running till the temp is up a little then take your car out, give it a boost and when you let go of boost check if a hudge cloud of black smoke is coming out, that will tell you if your rings are fucked,
here is another to check if rings worn or broken, could even be pistion ring turn.
when the rings are fucked, or turned as of pressure, you will get alot of oil spilling out of your oil points, shuch as near your gearbox mounting under the engine as the oil just poors out,
the most simple check for pistions is a Compresstion test which you can buy from any supplys such as halfords and ebay, they should read around 8, in the green of the compresstion tester, they all should read near or very close to the same as all cylinders, which will tell you if you have damaged any of the rings or pistions.
If your useing a chrome rocker cover then thats one problem, also if there is no ford stamp on the oil cap that means its a yellow bit of shit from your local halfords and the rubber that keeps the oil cap on is not doing its job because there cheap, ford supply them and there around 22-30£ also the problem with the chrome rocker cover is they do take a little while to heat then the normal standard rocker cover for an RST. you wanna get some wet and dry and remove as much chrome on the rocker cover where the oil cap sits as then it will have more chance to grip when on boost, if your pisition rings or pistions are pressureing due to broken internalls then you it would pop off even if its griped, warm (oil cap)
breathers on the RST get cloged due to crap oil used and not an often enuff oil change, remove all your breathers and make sure they are clean and oil free, advised to use something like a bukket or a hoes, blow throw them as oil will feed better than air, Ox.
its commen that the oil breathers colg and also the cap pops off, one thing not todo, as the engines are under alot of pressure being a turbo than a normal N/a car they need to beabe to release some pressure from that and mainly just pop the oil cap off if as said breathers are cloged so dont buy a chrome fixed one as it can brake parts..
there is a reasson to why the cap pops off, it shouldnt unless under alot of pressure, if the oil pip is cloged it will pop it off as all the pressure is going up from the pistion movement. if you was to drill a hole and fix the oil cap down, and you have cloged oil feeds and pipes you will crack a pistion, or on hard boost and hard driving you could send the rods to cloud nine and total your engine, and even crack your turbo fans that will then suck itsself into the engine and fuck your vauvles and stem seals.
then its time for a rebuild or a new engine deppends on damage, its the most stupidest thing you can do to an RST engine.
they are fast on boost because of the pressure the engine is under, and the turbo spin from a T3 turbo.
if you follow silly comments you'll end up with a nice 2half k maybe more bill for a new repalcemnt engine, just like i did as the stupid owner of mine before i got my hands onit had the screw in oil cap.
any more problems just ask...
there is a book on RST engines which i have and i can scan anything needed in, which it states in black n white to not fix the oil cap down and it gives you the reassons, to why you shouldnt.
i know you can get them rebuilt around 200ish from turbo tech here in nottinghamshire.
focus rs 1672
dnt rule out ring/ring land failure
