xr3i turbo engine
xr3i turbo engine
i have a low miles 1.6 injection engine,its very quiet and tight,no oil burning or usual tappet noises,if i got a used s2 turbo could i change the pistons in the injection engine and bolt the turbo manifolds to the head?or would the head need changing also,if that was the case could i use the injection cam as its the best 1.6i lump i have ever heard.ta,lee
If I'm correct head will fit fine, will need a turbo spec cam fitted. Bottom end doesn't have a oil feed for turbo so your best off finding a good RST bottom end or full engine and using your head.
Oil feed is easy to sort but would be more tricky to get return sorted. The heads i think are simalar but the exhaust valves are soduim filled to with stand higher temps. I rebuilt a rs turbo engine block using an xr3 i crankshaft as they have same number stamped on them. To get oil return you could have block drilled and tapped out with thread to take a fitting to take retun hos from turbo as its a low pressure return. Its surprsing what parts are the same when you look in to it.
The main difference between the engines is the pistons and management.
marky_g
15-08-2015 10:43 AM
