rs turbo cills
I can give you the number of a wicked welder just outside blackpool, Pm me if ur intrested, he's done a few series 1's he's done his 2 mk1 escorts, He cut sections outta another door and welded them into mine to get rid of some corrosion on the frame, even the body lad I use was amazed how good the work was
scott is a mint welder did the front end everythin from the door jambs forward inner arches the lot and to look at it when he finished you would have though it was original
works out neatest replacing inner and outer sills, plus floorpans, all at same time, as it means u have all new metal to spot/plug weld, keeps it all nice and neat when viewed from below
just beware that the best reproduction inner sills to get are the 1s with a captive nut already in place for the seat belt mounts, as some just have a predrilled hole and require u to retain part of the old sill, and the nothing ever lines up! oh and rear floorpans take a fair bit of persuading into shape/position as reproduction 1s must have been pressed by stevie wonder, miles out!
JK12
33
26-04-2021 12:09 PM
