help needed
Old Jan 26, 2009 | 11:26 AM
martinmilne's Avatar
martinmilne
Default help needed
right bit of a wierd one but my passenger side bearings and tca have gone but i was driving it home the other day so i could sort it out and the drivers side brake calliper started binding on the disc my question is is it to do with the passenger side or is it another problem ??
Old Jan 26, 2009 | 12:08 PM
martinmilne
any one ?
Old Jan 26, 2009 | 03:30 PM
Windle's Avatar
Windle
can't be related? only the anti roll bar joinning things together. take wheel of for a look sometimes a pulled brake hose or seized caliper etc?
Old Jan 27, 2009 | 03:35 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
Make sure your rubber boot round the calliper piston is not split. If so every time you wash the car water will piss on to the piston rust it and eventually it will seize.
Old Jan 27, 2009 | 09:24 PM
martinmilne
if it is siezed is it fucked will i need a new caliper ??
Old Jan 27, 2009 | 09:48 PM
martinmilne
Old Jan 27, 2009 | 10:07 PM
kidsRS's Avatar
kidsRS
Im having the same trouble mine is getting water in. just push the piston in and out a few times and get some wd40 inside that rubber and free it off. it will seize again but will see you a bit more life in it.
Old Jan 27, 2009 | 11:58 PM
studabear's Avatar
studabear
get another caliper, exchange units arn't too bad pricewise or a decent second hand item
Old Jan 28, 2009 | 09:56 AM
kidsRS's Avatar
kidsRS
yeh i think there 40 quid on ebay branny!
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
