rs2000 converison??
it is but its easier to do on a mk3 escort, on the mk4 you need to space the subframe with washers alittle and modify the drivers suspension turret to get clearence, the one ive seen was tapped with a hammer,
![](https://i200.photobucket.com/albums/aa215/koskar1/RS2K/Mk4%20RS2000/2006_12_28/korvake2.jpg)
I didn't modify turret on my setup. Only modified part of engine mountings was this:
. More pics (some old in folders) here: http://s200.photobucket.com/albums/a...000/?start=all
thatl be me then lol
yeah i cut the whole mounting plate off and then made one up to suit using the original rs2k mount as my cvh one cracked when i was only using the zetec, i also did it so that i could lower the engine so not to cut a hole in the bonnet, so the gearbox and engine are about 10-20mm lower but ive got an rst bonnet with the vent covers so one cover has rubbed a tiny tiny bit on chaincover but will be fine if you dont use a plate.
its not an easy fit, only have space for my pinky finger between the lower pulley and inner wing so its a up from underneath job i felt but id use a ramp if you can as it makes life so much easier as i had to dummy fit it several time to get it right.
![](http://i80.photobucket.com/albums/j171/fonfe123/07-05-08_1733.jpg)
![](http://i80.photobucket.com/albums/j171/fonfe123/07-05-08_1250.jpg)
![](http://i80.photobucket.com/albums/j171/fonfe123/07-05-08_1731.jpg)
ive just bought a 2.3 though with the intention of building a 2.3 hybrid using the rs parts but have decided to turbo it instead to do something different.
drop me a pm if you got any more questions fella. do check out koska's pics though as they are quite good, ive got a load of it going in but dont know how to make my album open for anyone to see im afriad.
2.3 hybrid is a cheap conversion if everything is setup to use the rs2k lump. will give loads of torque and around the 170-180 figure running on the OE system. for best results something like a unichip should be used
Pwrs2k
120
16-10-2015 03:16 PM
Fordmad!
15
27-09-2015 06:24 PM
