Air/ Fuel Ratio gauge?
Old 17-01-2009 | 11:10 AM
adam.d's Avatar
adam.d
Default Air/ Fuel Ratio gauge?
Can this be fitted to my RST? Anyone know how to wire it up?
Old 17-01-2009 | 12:05 PM
Doughnutter's Avatar
Doughnutter
They all come with directions but generally speaking you will have a switched live in an earth and then the 3 wires for the lambda sensor. Will fit any car with a lambda, and if you don't have a lambda just drill a hole in the exhaust, weld a big nut on and away you go
Old 17-01-2009 | 12:06 PM
Ad4m RST's Avatar
Ad4m RST
Have had one fitted (bottom gauge), think they run off a lambda...
Old 17-01-2009 | 12:07 PM
Ad4m RST's Avatar
Ad4m RST
Beat me to it...
Old 17-01-2009 | 12:08 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
http://cgi.ebay.co.uk/Innovate-Motor...1%7C240%3A1318
Old 17-01-2009 | 12:11 PM
adam.d's Avatar
adam.d
Shit! has my car got a lambda sensor? Don't think I've noticed! infact I'm quite sure it hasn't !!!
Old 17-01-2009 | 01:23 PM
Karlos G's Avatar
Karlos G
Balls Deep!
lol no mate it most certainly hasnt, and it's not any old lambda sensor you need it's a wide band lambda sensor. A decent one will cost £200 upwards mate plus your gauge!
Old 17-01-2009 | 07:03 PM
RSandy's Avatar
RSandy
dont necessarily need a wide band sensor, will be far more accurate with 1, but if its just a basic air/fuel gauge being fitted, then a basic lambda will do. most newer cars will only run the narrowband type as standard anyways
i think VAG bosch lambda's are the 1s to go for, pick them up on ebay for about 40quid new, but if u just want a reall boggo sensor, they like a tenner on ebay, plenty of them
Old 18-01-2009 | 06:56 PM
Badman38's Avatar
Badman38
narrowband lambda sensors with gauges are hopeless and i think just a waste of time, just buy yourself a wideband..
sean
Old 18-01-2009 | 07:02 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
If this is an MFI RST, I wouldn't bother!!
You'll just shock yourself with how poor the AFR's are!! A bit like my first ACT gauge, I was quite happy with my Chargecooler set-up until I got the gauge and saw the temps really didn't cut it.
Old 18-01-2009 | 07:16 PM
RSandy's Avatar
RSandy
sean
im not denying they hardly the height of accuracy, but some people just fancy a gauge that basically looks pretty and serves a purpose, however small
wideband set up is a bit extreme for you average run of the mill rst really, plus costs massively more
Old 18-01-2009 | 08:25 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
RSandy- sorry but narrow band gauges do absolutely nothing other than flash LED's like a xmas tree ... All they do is tell you if you're leaner or richer than lambda 1.0, which is completely useless at anything other than cruise!
Old 18-01-2009 | 10:27 PM
RSandy's Avatar
RSandy
well i did kind of say 'basically looks pretty and serves a purpose, however small'. was a polite way of pointing out it just looks flashy, without makin the thread starter feel like a gimp
maybe its what he wants, who am i, or anybody else, to tell him he should or he shouldnt. id guess its fair to assume hes only on about a basic 1 like this, cos if he was after a full wideband set up, chances are he would have a fair knowledge of such things as if his car has a lambda as standard
Old 18-01-2009 | 10:43 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
The thread starter just asked about a 'air:fuel ratio gauge'.. didn't specify narrow or wide-band
Old 18-01-2009 | 10:46 PM
RSandy's Avatar
RSandy
well as an educated guess, id say if hes not fluent in the ins n outs of lambda sensors n the system on his own car, its fairly safe to say hes not going to be after a full wideband posh set up lol
or i could be way off the mark......but im gna guess hes looking at a gauge that costs about 30quid on ebay
timsrs
13-11-2018 12:48 PM
01-11-2015 07:53 PM
Mark RS
12-10-2015 07:01 AM
Brickhouse
14
03-10-2015 08:28 PM
20/20 vision
29-09-2015 12:27 PM
