need to lower boost
Mk3 capri 3.0l
need to lower boost
Hello i think my car is running to much boost keeps cutting out when i boot it, can anybody tell me how to lower the boost, will be appreciated.
cheers
Dom
cheers
Dom
If you simply want to lower the boost, just undo the actuator (held on by a small circlip) and wind the bar so it's a bit longer. This is done from under the car. Make it so the bar is just too short to fit back on, should be about 1/2 a hole out so you have to pull the bar to hook it back over. I know this sounds confusing but when you get under the car and have a look it will become a lot clearer
Balls Deep!
IMO MFI RS's need a setup once a year just to keep things tight, it's £100 well spent.
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
