rs turbo holds back afta 65mph+ ??
i swapped my turbo's ova 2day, using the same actuator, and it feels like its running 5psi an i usually run 16psi, 2cd 3rd 4th 5th hardly hav any torque/boost, cud my actuator b at fault??
Colossal Pervert
If the turbo is the same, and you installed the actuator with identical pre-load, then it should be similar.. otherwise the turbo is fucked or you have a serious air leak.
All roads tend to lead to user error.
its a diffrent turbo fitted, but i took my actuator + bleedvalve off my previous turbo an used it on the replacement , not sure wat u mean by (did you unscrew the threeded bit at all?) iv looked 4 air leaks cant find any
ok i changed the actuator an its boostin ok now, only thing buggin me is the dumpvalve is really quiet wen it dumps even on heavy load at 6000rpm? the dumpvalve was workin ok on my shagged turbo before i changed it? any idea's?
