HELP!!! missfire
hi there i done an engine change on me s2 and the engine was running fine when i took it out the other car now its in mine there is a miss fire when u rev up its gone and when u are driveing slow it there and when u pick up speed its gone the only thing i have not changed is the metering unit cud this be the problem and as my sump gasget is leaking somone said it might be that cud some help me plz
hi there i think me turbo might be buggered i changed the meetring unit and its idleing fine now and i drove it about and the missfire went and then when i put me foot down and it boosted up and come back i think its over boosting as well anyone know wot it wud be cheers
yea its just a normal t3 turbo yea there is blue smoke its pumping a bit of oil out and there is play in the shaft but wud it cause the missfire to come and go
well im not sure about the missfire but airleaks will cause a misfire as Karlos said... if there is play and oil then your turbo is definately leaking. There should be a tiny bit of play but not a lot at all.
I would change the turbo as it will need doing anyways, then take it from there. One thing at a time is always best otherwise it starts to get overwhelming.
Ginge !
23
28-05-2005 01:06 PM
