Installed boost gauge and am AMAZED at the results.
I installed my boost gauge the other day and I thought id warm the car up and take it out for a spin to see what she was reading.
2nd and 3rd gear on full throttle, it peaks just over 1 bar, id say its around the 15 to 16 psi mark.
I was shocked as I thought it was running standard boost, should have known it wasnt as it has a boost controller in the car (mechanical one)
In a way im a little dissapointed as I thought i could squeeze a few more psi out of her but i dont think it is safe to do so,
And the quest for more power continues!
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
Balls Deep!
If your on a stock engine and turbo you may be able to squeeze a couple more psi out, but you'll need a good FMIC, and will have to hope that your metering head can supply enough fuel for it.
To be honest if you have not had it set up, i would at least go for a power run to make sure your not running dangerously lean already!
thanks mate, ill get it down the rollers for a proper set up. It will benefit from that anyways... may i ask what set up you got for 10psi at 182 bhp?
Balls Deep!
Yes mate of course!
Fully ported and flowed head with 3 angle valve seats and stainless valves.
Piper 285T Cam, followers and Vernier Pulley.
Radtec Full Front Mount intercooler with twin Spal Fans.
Stock T3
-31 Collins Actuator
K&N Filter
Scorpion Exhaust
Turbo Systems Chipped ECU
Bailey Breather venting to atmosphere.
I think thats it....
Stock T3
K&N Filter
Scorpion Exhaust
Yes mate of course!
Stock T3
K&N Filter
Scorpion Exhaust
Stock T3
K&N Filter
Scorpion Exhaust
Thanks for that build spec matey, it would suit my budget no end! Are you running standard injectors with mfi?
What you reckon it would peak at 15 psi or would it go pop lol?
Balls Deep!
Thats exactly right!
The Headwork and Cam make a huge difference to the flow (VE) of the engine, the easier it can get gasses in and out the greater your perfomance will be. Although my power is made at a relatively low boost (pressure) the is a lot of air (volume) being forced into the chambers and thats what counts.
If i was to have a standard head and wanted to make the same power the boost would have be about 16-18psi to get the same volume of air in!
Headwork will cost you anything from £350 upwards depending what you have done mate, http://www.cylinderheaddevelopments.co.uk/ these are the boys to speak to!
There is only one type of injector for MFI mate so yes they are standard.
Mine peaks at 17psi and then gradually drops down to 10psi because a stock T3 cant flow enough on my engine to hold 17psi over about 4000prm.
As your RPM increases the engine requires more and more air flow from the turbo to hold your desired boost pressure, so my next upgrade is a Stage 2 T3!
nice mate, thanks for your advice and build spec. A little random question.. i fitted some rear springs, supposed to drop it 50mm but it aint really that low, im a little disapointed... it is defo lower than what it was but not what i thought... will it drop a little more as i drive it? Ill fit the fronts tomorrow too!
thank fuck for that... i had a few guys from work around me giving a hand as i lowered it to the floor and they were like oh is that it... i thought the same but wondered if it lowered up a little more... im glad about that! Will it be noticebaly lower? lol
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
