Replacing Ecu on RST S2
Hi
I found a chipped Ecu to replace my standard BLUE-RED-BLACK Ecu.
The problem is that the chipped ecu is HEARTS & DIAMOND Type.
Can I fit the ecu on my RST s2?
Will have running problems with this Ecu??
Thanks
Thanks
won't be a problem mate,
The diamond and hearts ECU has more features like the knocksensor. When it's not on your car is won't be used and it won't be a problem. Running will be the same as your old ECU unless you are going to change your boost, then it needs to be set up again
Ok!!, so no problem, Ecus are compatible??
My car have knock sensor so standard ecu have knocksensor control.
CheeRS
JK12
33
26-04-2021 12:09 PM
DixieTheKid
14-09-2015 09:04 PM
