oil cap pops off
Old 28-09-2008 | 08:47 PM
nzwhiteboy's Avatar
nzwhiteboy
Default oil cap pops off
hi guys.
i got a s2 RST and have a problem of the oil cap popping off under boost... what would cause this? i gather it would be from excess pressure maybe?
cheers
Logan
Old 28-09-2008 | 08:49 PM
louie1's Avatar
louie1
make sure the rear oil return/breather from the back of the rocker cover are free from old dried oil and free flowing.
Old 29-09-2008 | 08:33 AM
Antti O's Avatar
Antti O
Car runs smoothly idle when oil cap inserted correctly?
My ex rst did blow off the cap when piston was broken because of pinking.
But the car idle was not smooth.. one cylinder leak.
Old 29-09-2008 | 02:33 PM
mark-rst's Avatar
mark-rst
As above, check breather system for blocks and i would also do a compression test on the engine
Old 29-09-2008 | 06:57 PM
Moonie's Avatar
Moonie
Also make sure the one way valve between the inlet manifold and breather system is working correctly. If it is sticking open and not closing under positive pressure (turbo pressure) then it will be pressurizing the breather system/sump forcing the cap off.
Old 29-09-2008 | 07:08 PM
Rick's Avatar
Rick
the caps need replacing, could just need a new one.
Old 29-09-2008 | 07:12 PM
StephenC's Avatar
StephenC
..BS Motorsport..
As rick says, when mine was run in and setup it blew the cap straight off the first time it saw full boost, 10 year old cap wasnt up for it. Only cheap from ford (£4 I think).
Old 29-09-2008 | 07:15 PM
mark2's Avatar
mark2
hi fella
as said do a compression test first
if its all good
try putting 1 ring of electrical tape around the rocker cover/oil filler lip as the rubbers do wear out also if its not a standard engine then i would put a after market breather system on the car as its a fact the standard system are shit
mark
Old 29-09-2008 | 08:52 PM
nzwhiteboy's Avatar
nzwhiteboy
cheers for all your guys help. i will endeavour to do these things in the weekend. it sucks not having this kind of help over here in NZ. there are a few places but not as many people have the knowledge.!!cheers
IainRS1700T
25-09-2015 06:44 AM
oilman
Trader Parts for Sale.
23-09-2015 07:32 PM
Brickhouse
21-09-2015 11:00 AM
biggiejody
19-09-2015 10:25 AM
shoppel
Ford Escort RS Cosworth
17-09-2015 09:03 AM
Quick Reply: oil cap pops off
