anyone help with missfire
Old 17-09-2008 | 03:54 PM
mark@fordrs.org's Avatar
mark@fordrs.org
Default anyone help with missfire
hi. im currently on with putting my s1 back on the road and im having trouble with missfiring under boost but only once warm, i know it does need a gud set up but i dont want to take it some were to be set up and end up fitting parts all day long to cure this problem first, cheers mark
Old 17-09-2008 | 04:48 PM
bloopeta's Avatar
bloopeta
How do you mean only when boosting when warm??? Surely you wouldnt be boosting when cold anyway??
Old 22-09-2008 | 07:50 AM
mark@fordrs.org
ok then sorry, will boost up a few times once warm but starts missing once temps get a bit higher, would too much boost pressure cause this
Old 22-09-2008 | 08:49 AM
wardchris's Avatar
wardchris
Hi Mark i would start with basics ie plugs, leads, etc etc and make sure everything is spot on, could be the plugs breaking down once temps get high or the leads etc etc...
As for the boost what spec is the engine and what boost are you running ?
Chris.
Old 22-09-2008 | 07:11 PM
crashley's Avatar
crashley
check plug gaps to boost might be blowing ot spark
fish6634
Ford KA
02-08-2015 01:02 PM
ginger1979
31-07-2015 09:56 PM
Ginge !
23
28-05-2005 01:06 PM
FletchCossie
19-07-2004 08:17 PM
AlexD
26-02-2004 08:59 AM
Quick Reply: anyone help with missfire
