Fuel Pump Relay Keep Blowing???
Old Sep 12, 2008 | 08:48 PM
stephenbatey's Avatar
stephenbatey
Default Fuel Pump Relay Keep Blowing???
Alright all, got a problem with the S2. Here goes, the fuel pump relay keeps burning out, i`m going through one a month approx and this is the 3rd one to blow today Anybody got any ideas on what could be causing this or had this problem themselves as it`s staring to do my head right in????
Thanks
Old Sep 12, 2008 | 09:20 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
the connections are shite mate
Old Sep 12, 2008 | 09:27 PM
stephenbatey
So whats the best way to sort it?? Don`t want it happening again
Old Sep 12, 2008 | 09:31 PM
orion_crazy_carl
orion=mini saff
is the pink block melted to?are the pins melting on the relay?
Old Sep 12, 2008 | 09:35 PM
stephenbatey
Yes mate
Old Sep 12, 2008 | 09:41 PM
orion_crazy_carl
orion=mini saff
i snipped the block off and soldered new spades on mine,never had a problem after tht,bit extream tho,u can try making the connection better by squeezing the connection together more so it bites the relay more if ya get wht i mean?!lol
Old Sep 12, 2008 | 09:45 PM
stephenbatey
I`ll replace the spade connectors to be on safe side mate. Thanks for your help mate
Old Sep 12, 2008 | 10:12 PM
Chris69's Avatar
Chris69
either bad connection or your fuel pump has seen better days and is drawing too much current.
Old Sep 13, 2008 | 06:49 AM
stephenbatey
Is there a way to test if my fuel pump to see if its on its drawing too much current??
Old Sep 13, 2008 | 05:13 PM
stephenbatey
I`ve sorted the relay with new spade connections so, fingers crossed, it shouldn`t happen again. Can anybody tell me how to test the fuel pump is working right (ie not drawing too much current)??? Thanks again
Old Sep 14, 2008 | 09:03 AM
stephenbatey
Anybody??
Old Sep 14, 2008 | 10:36 AM
orion_crazy_carl
orion=mini saff
need to get a multi meter on it,but im not sure how much it should be drawing!if it aint noisey thn i would say its ok
Old Sep 14, 2008 | 10:41 AM
stephenbatey
Cheers mate, it aint noisy so fingers crossed, if the relay burns out again i`ll get a new pump on and take it from there. Thanks again
Old Sep 14, 2008 | 10:49 AM
orion_crazy_carl
orion=mini saff
if u change the pump its worth running a nice new cable to it,its the black wire with a strip in,normally purple,goes straight to the pump
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
