cvh help timing ect
Hey all a mate of mine said my timings out an that he set the crankshaft and said that the rotor arm is on cylinder 4 he said the timing belt needed taking off and moving two notches so its on no1.I dont no what im doing really but went to av a look earlier.
I turned the camshaft till the small pip on the crank pulley was facing upwards.
There is no markings on the camshaft pully so i took the distributor cap of and the rotor arm was on cylinder 1.Can someone tell me how to set the timing plz.
Also i got a three way bleed valve i wanna fit i no its 1 to turbo 1 to bleed air and 1 to atuator what do i do about the boost control solaniod as im taking boost and atcuator of it.cheers chaps
Ben26
27-08-2015 08:56 PM
