Turbo pipe that fits ??
Old 22-07-2008 | 12:17 PM
S2_RST_DK's Avatar
S2_RST_DK
Default Turbo pipe that fits ??
Hi
This is the turbo pipe/charge carrier that Jamsport delivered with my engine, but as you can see its not a direct fit.
Since i dont know much about the different turbo pipes i was hoping someone could help and tell me which pipe i need
Old 22-07-2008 | 12:23 PM
rst230bhp's Avatar
rst230bhp
that charge pipe is of an early s2 the one you need is a 90 spec one.
Old 22-07-2008 | 12:25 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
as said.u need 90spec 1 or 1 off a fiesta turbo
Old 22-07-2008 | 12:26 PM
rickbartlett
G911 TTA
or get an earlier rocker cover,then it will line up with charge carrier
Old 22-07-2008 | 12:27 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
looks like they have choped the end off?
Old 22-07-2008 | 12:34 PM
S2_RST_DK's Avatar
S2_RST_DK
Thanks
And yes they have chopped a pice off it, dont know why, but it is not looking .... great
Old 22-07-2008 | 12:38 PM
clarke5700's Avatar
clarke5700
does look good must admit if you need a fiesta turbo crossover pipe i think i mite have one?
Old 22-07-2008 | 06:49 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
Have you tried speaking to them directly ?? They should have been your first point of call really.
Definately early S2 item, but you have a later rocker cover.
Either get a later 90 spec or Fiesta charge carrier...or an ealry rocker cover.
HOWEVER I would first suggest speaking to Jamsport as there may be a reason behind it.
Old 23-07-2008 | 08:28 AM
S2_RST_DK's Avatar
S2_RST_DK
Hi
Thanks Clarke5700, I have a friend that will try and make an bracket so i can use this pipe for now, i it does not work, i will sent you an PM.
rs shawn... I have spoken to them lots of times and will call them again.
Henrik
Old 23-07-2008 | 08:31 AM
Antti O's Avatar
Antti O
Try to find 88 spec rocker cover and new pipe.
I think its the easiest way to fit it.
My EFI conversion and pipe:
http://bp3.blogger.com/_-EspJygF5lE/...1600-h/007.JPG
marky_g
15-08-2015 11:43 AM
track.focus'd
12-08-2015 06:53 PM
Quick Reply: Turbo pipe that fits ??
