hello all just brought my self a s2 rs and when i brought it it was not running to well it seems to be really flat and when the boost comes in it starts to pop and fart
it has had changed
plugs
leads
dizzy
coil
fuel filter
but still the same can anyone help me as it is really bugging me
check the position of the dizzy with the head, try rotating it to retard/advance bout a mm at a time, but dont go thrashing it, you will know if it makes a difference from driving safely
tried to adjust the dizzy made no difference it only does it when it is warm i have found today i ran it when it was cold and it was fine but as soon as it is warm it plays up
I had this years ago on my S1 when the Ford dealer overfilled with oil - Fine when cold but sick when warmed. Took another branch of dealership about a week to clean out and replace parts to remove excesses. It's OK though they are no longer a Ford dealer!
take it for a set up dude! will prob be cheaper by the time you have done buying parts that are not needed!
it will run great an go well
needs to fix the problem really before it can be set up as cars not really drivable, as soon as you put the engine under load(as in pulling off slowly) it starts to miss and sounds like antilag poping and banging!
