gearbox mounts
is half man, half amazin'
gearbox mounts
are these comment to go?????????????????????????????
mine are fuck off havin a bit, well a big bit of a race from the taffic lights
can you get polly 1's and are they better?
i made my own heady duty gearbox-mounts, will post some pictures if anyone is interested?
first off, i took the 2 original mounts, chopped off all the "flanges" and threads around the mount, so that i had just a square rubber thing with 2 metal plates on. then i drilled a 10mm hole through the mount.
took a third mount and did the same with this, and cut the mount in half. then i mounted the two orginal mounts on the car, took the third mount and sat it unterneath the beam holding the box, and put a long m10 screw with a locking nut through the whole lot tightened it on hand-feel momentum.
bullet proof and fail-safe for almost nothing
sorry about my english, it's early in the morning...
rsguy
44
29-09-2015 03:29 PM
DavidK
27-09-2015 02:55 PM
