actuator test
Old Apr 20, 2008 | 07:37 PM
Dragsteer's Avatar
Dragsteer
Default actuator test
I have question about wastegate actuator, I buy chipped ecu, so now I will run about 1 bar of boost, and have one actuator from some t3 turbo from nissan. so just want to know if possible to test actuator with air pump (with pressurre gauge on it) , so pump air in actuator and see when it start to leak air?
Edit: Will cosworth actuator fits on rs turbo?
Old Apr 21, 2008 | 08:01 AM
MorryRS's Avatar
MorryRS
Just attach a length of silicon hose from the pressure guage the the outlet on the actuator . Pump up the pressure until the rod on the actuator starts to move and till its right open and it will let you know the pressure of the spring.
Old Apr 21, 2008 | 11:22 AM
Dragsteer's Avatar
Dragsteer
thank you !
Old Apr 22, 2008 | 09:30 AM
Dragsteer's Avatar
Dragsteer
will actuator from sierra cosworth (2wd or 4x4?) fit rs turbo? instead of buying -31
TPM961
Jan 15, 2018 10:50 AM
tankybaby66
Feb 6, 2016 02:24 PM
Fiddy
21
Sep 29, 2015 06:10 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
hopper350
Sep 4, 2015 12:53 AM
