engine fitted wont start tho!
it starts, but cuts straight out, i recently had new engine put it, jus cant get it to run, there is no fuel going to the injectors,only fuel there is , is the cold start valve supply, which helps it start but cuts straight out cuz no petrol in injectors ,ive changed the
metering unit +plugs+leads today, any ideas people or sumthing ive missed cheeRs
Location: Dewsbury, The parts were they don't abduct their own children!
Sound silly but is the fuel pump wired the correct way round (electrically?)?
As no fuel will be pumping?
Also have you conneted up the brake booster hose that goes from the inlet maniold to the brake servo? If that hole that the pipe goes into the inlet manifold then you wont get head pressure and it will struggle to start?
wen i turn the ignition, it primes can hear it,
not sure about the brake booster hose that goes from the inlet maniold to the brake servo, cud do wiv a pic of it
cheers 4 ya help m8
cheers 4 ya help m8
i know this sounds really stupid but is the bottom intercooler hose on properly because i had the same problem and thats all mine turned out to be hope that helps in any way
JoeyBoyden
04-01-2024 02:36 PM
Gadget
Ford Escort RS Cosworth
14-08-2015 07:19 AM
Gadget
13-08-2015 08:19 PM
track.focus'd
12-08-2015 05:53 PM
Zoggon
10-08-2015 10:39 AM
