MK3 Shell resto - Edit : ACID DIPPING companies
As above, i've got a Series 1 which i took off the road over a year ago, been stripping it down back to the shell and collecting parts for the rebuild. Thing is i want to get the shell done professionally cos i aint got the skills or time to do the welding and painting. So can anyone recommend anywhere around Derbyshiire/South Yorks, maybe Notts that can do a totally mint shell resto.
And how much does it cost roughly for a proper decent full respray? obviously you get what you pay for but i'd rather get it done right.
Plus what about costs of welding?? got gen ford panels - front panel, wings, front cross member and non gen sills inner & outer.
R-apidly S-kint
R-apidly S-kint
the front end is easy to do mate im no professional but i did mine the sills are a bit tricky but not that bad
i prepped all mine and primered then it cost me 400 for a full respray and200 for doors boot bonnet tp be painted mint job
As for the sills.... i heard that if your weldings not upto scratch you can warp the panels which would would'nt go down to well
Fair play to you mate for doing yours though, think i might have to get the welder out and see how i get on in practice.
But just incase my welds look like pigeon sh*t do any of you have a rough guide?
If you dont mind the travel,jacko at blueovalgarages.com does resto work,check out his web site they did the fast ford mag's res series 2,and it looks mint now.Teesside is only 2-3 hours away
in the middle of doing mine was going to have a go my self but a freind of mine says it looks easy till you remove the wings etc and then it like o shit look at that mess and guess what he was right the job cost me £1000 for every thing to be replaced from the front doors forward even took the sthil saw to a mint mk 3 estate for some parts
Cheers guys, i'll look into the links.
I've been looking at getting the shell acid dipped before i have the new panels fitted, that way i can get rid of the rust in hard to reach places plus if it uncovers any nasty suprises that can be dealt with before i have it sprayed.
I phoned a company in the midlands www.surfaceprocessing.co.uk and they gave me a quote of £745 for the shell, doors, tailgate to be treated + another £800 for the E-coating.
Just wandered if anyones used this before or knows someone that as, plus are there any other companys that do this so i can get a quote - surface processing are booking in for September 2008, time too save i suppose . Cheers
Go to the link above, then click on "FOR CARS" shows a mk1 escort getting dipped, looks mint.
http://bbs.rsownersclub.co.uk/showthread.php?t=119652
If you check the link . Someone off RSOC is doing the same to a S1 and the company that done his dipping etc looks spot on and they also do welding etc
if you get it accid dipped mate get it e coated or the inside of all the places you cant get to will rust again and do it after all the welding has been done to
Jacko
Thanks mate, i'd go for the e-coating for sure, i read about the problems with treating areas unreachable by standard painting such as any box sections which would be left bare metal unless e-coated, just rot inside out.
mk3ste
17-10-2021 10:09 AM
rsguy
44
29-09-2015 03:29 PM
