fitting newman cam ?
Old 17-01-2008 | 09:59 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
Default fitting newman cam ?
Do you need to put 2 spacers on under the rocker on the rocker posts like it says in performance ford mag ?
Any tips on fitting the solid lifter cam ?
Old 18-01-2008 | 11:58 AM
Badman38's Avatar
Badman38
Default Re: fitting newman cam ?
no m8 not with there new style solid lifter just set them to inlet 8-10 exhaust 10-12 thou job done, there were a few problems with the earlier lifter.. have you got the tool for holding the lifter?
i'll send you some pictures tonight of pumaracing head..
sean
Old 18-01-2008 | 12:29 PM
G2RSR's Avatar
G2RSR
Bodybuilding
yes mate ive got the lifter adjustment tool
i was just worried i had to go to the scrapyard to get some spacers off a old cvh head
Old 18-01-2008 | 05:42 PM
G2RSR's Avatar
G2RSR
Bodybuilding
ok ive fitted the cam but the lifters keep coming loose how tight do you have to do them and the best way of doing it
i did them real tight but they still come lose
Old 18-01-2008 | 06:04 PM
Tim's Avatar
Tim
ok ive fitted the cam but the lifters keep coming lose how tight do you have to do them and the best way of doing it
is there a way of using the lifter adjustment tool without it slipping round in your hand
quite tight u must use loctite also
Old 18-01-2008 | 06:48 PM
Badman38's Avatar
Badman38
how long ago did you purchase the cam and like tim said they have to be very fooking tight.
sean
Old 18-01-2008 | 06:50 PM
G2RSR's Avatar
G2RSR
Bodybuilding
i got it just the other day i set them all up and they have come loose twice now
Old 20-01-2008 | 10:05 PM
rstdave's Avatar
rstdave
Sounds obvious but did you put the lifter clamp in a vice??? You won't be able to do them up tight enough holding it in your hand...i used 2 spanners, one holding the bolt to stop it moving when tightening the nut, the other to do the nut up.....as said above do it up as tight as you can. I've got the old lifetrs and had to use 2 spacers, didn'r realise they'd rectified that issue now
Old 20-01-2008 | 11:41 PM
G2RSR's Avatar
G2RSR
Bodybuilding
yeah mate thats what i did in the end went out and bought a vice then put the adjustment tool in the vice all good now
Old 21-01-2008 | 09:56 PM
rstdave's Avatar
rstdave
Cool...glad it's all sorted, not a job u wanna be doin too often is it!
Old 22-01-2008 | 06:15 PM
GINGExR2 T's Avatar
GINGExR2 T
Thinking of getting a newman cam for my XR2Turbo, what sort of rev 's can the solid lifters run as my limiter is at 6500rpm at the moment and it drives me nuts
Old 23-01-2008 | 09:10 PM
DazC's Avatar
DazC
Beyond 6500rpm is the reason why you change to solid as the hydraulic lifters pump themselves open beyond there as they can't drain off fast enough.
Old 24-01-2008 | 07:06 PM
GINGExR2 T's Avatar
GINGExR2 T
Cheers Daz, I new that already mate hence the limiter, Just wondering if there was a limit on the solid items???
JoeyBoyden
04-01-2024 02:36 PM
RUBY123
22-10-2023 12:04 PM
Danielbetty
03-10-2015 06:01 PM
martsmotor
Ford Focus Range
27-08-2015 08:08 PM
JoeyBoyden
20
22-08-2015 03:23 PM
Quick Reply: fitting newman cam ?
