puddle in my car lol
fucking bad luck with car at mome. slight puddle in back footwell behead passenger seat. how the fuk am i gna find out where thats cumin from lol. no water on back seat on enyting. bit of water in boot but loads in back footwell.
where do i start man
same happened to mine last weekend so i simply ripped all the interior out (seats, carpet and sound proofing under carpet) then put hose pipe on till you see water running somewhere mine happened to be one of the opening rear quarters but yours is probably boot seal or seals round rear lights, remember to make sure you dry all the sound deadening out properly i've had mine by radiators for a couple of days now
st170 breaking
sunroofs drain into the sills and if your sills have been welded up and no drails left they will fill up and then drain into the car thru the inners, worth listening out for water in the sills while your driving
ive had em leak thru the spoiler holes or rear lamps then you brake and the water washes from the boot into the foot wells
bought a 3i once that the spare floated in, was right up to the top of the spare wheel well, mate drove it home and got a right shock at the 1st roundabout slowing for 70 to 0 tidal wave thru the car
st170 breaking
Originally Posted by diesel
my s2 is the same but in the front foot wells there is swimming pool in mine. i got more water than a fire engine
screen rubber, sills filled, fuse box area rotten, battery tray area rotten, inner arch rotten
also maybe the heater matrix leaking but you'd prob notice the engine seizing if your losing lots
focus rs 1672
check door seal at top corner of door when closed
same happened to me and it was the door seal that was flat and not sealin right,the water would leak into inside of door and run onto passenger rear footwell
is it me or it seems like a common prob with escorts for seals to go etc
