Recirculating Dump Valve?
Old Jan 2, 2008 | 09:57 AM
RsDarren's Avatar
RsDarren
From: Dewsbury, The parts were they don't abduct their own children!
Default Recirculating Dump Valve?
Just wondering if would be ok to fit a recirc dump valve to my S1 RST?
I'd imagine it would be ok? Just not heard anyone talk about it on here?
Darren
Old Jan 2, 2008 | 12:08 PM
homer j's Avatar
homer j
why would you want to mate? in all honesty you won't need one until you start running GT30 size turbos with massive boost like around 2 bar.
Old Jan 2, 2008 | 02:32 PM
RsDarren's Avatar
RsDarren
The car will be running fair bit of boost, but not that much? ha
Just would like to put a dump valve of some sort, not keen of the noisy ones and don't want to blank it off. So it seems that the recirc is the way forward?
Old Jan 2, 2008 | 05:13 PM
Oranoco's Avatar
Oranoco
Absolutely no point. A DV does fuck all on these cars. The only benefit is the noise (if you like it). Absolutely no point fitting one to then not hear it.
Best bet save some pennies and spend it somewhere else on the car where it will have some benefit
Old Jan 2, 2008 | 06:24 PM
Dragsteer's Avatar
Dragsteer
he asks about recilculating DV, which dont make noise because air went in inlet mainfold , not in atmosphere.
Old Jan 2, 2008 | 08:16 PM
homer j's Avatar
homer j
you could probably do it by routing the DV back into the intake hose between the metering unit and the turbo. still think it'd be a waste of time and money though personally.
Old Jan 3, 2008 | 08:08 AM
RsDarren's Avatar
RsDarren
That was what i was thinking. I know that it may seem like a waste of money but a close friend of mine has the same set up running pretty much the same boost (a fair bit more than standard) and his turbo has just blown to bits. The company that rebuilt it has asked him did he have a DV or blanked it off? He had blanked it off and they said that would have help to the breaking of the turbo unit?
So to spend £80 on a dump valve to make me save £100's on a new turbo?
Thanks for all the advice though chaps
Old Jan 3, 2008 | 12:04 PM
Oranoco's Avatar
Oranoco
They are talking complete bollocks mate. Providing the turbo was a fairly normal Garrat, not T4 or larger or running 30psi of boost. This has been discussed on this very forum time and time again. Or was your mate trying to chuck a shed load of boost through an old standard turbo?
You do not need one, there is no benefit to having one recirculating or otherwise.
If you still want to go ahead and fit one of any type go ahead just don't be fooled into thinking it will offer any additional protection. In some cases it can cause the turbo to overspeed which is potentially damaging.
Old Jan 3, 2008 | 06:01 PM
RsDarren's Avatar
RsDarren
I didn't know about that, thanks.
Will have to re consider?
Darren
Old Jan 3, 2008 | 06:51 PM
Oranoco's Avatar
Oranoco
Just trying to help mate not lecture. I hate to see people part with cash for shiny shit that they just don't need
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
