Cam fitting
Old Dec 12, 2007 | 10:26 AM
Benxrrst's Avatar
Benxrrst
Default Cam fitting
When a new cam is fitted do i need to run it in as ive been told i need to hold the revs @ 2.5-3k for a couple of minutes its a standard cam.
Old Dec 12, 2007 | 10:52 AM
Red_bull's Avatar
Red_bull
i heard the same. Probably because of the oil getting earlier into the head.
Old Dec 12, 2007 | 10:59 AM
Benxrrst's Avatar
Benxrrst
Ok nice one was gonna see if any of the big tuning companies doit?
Old Dec 12, 2007 | 01:14 PM
Red_bull's Avatar
Red_bull
I don't know, but the cam i got back from the tuning was covered with a kind of grease special for running in... maby they use that stuff
Old Dec 12, 2007 | 01:42 PM
swerv's Avatar
swerv
yes you have to work harden the cam, it wont last 5 mintues unless you do it, if the car overheats do it in 2 stages
Old Dec 12, 2007 | 04:12 PM
LEE-RS's Avatar
LEE-RS
Custom
Hold it on 2.5 - 3k for 20 minutes to run in a cam
Old Dec 12, 2007 | 04:31 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
We use Graphogen on new cams. Put some on the cam-lobe and some on the base of the lifter. The car needs to NOT idle for the first 20 mins of its life. Alot of people make the mistake of running the cam in whilst sitting still. Drive the car, but just try not to let it idle. If you rev it to 2500 for 20 mins whilst not moving, chances are it will over-heat.
Old Dec 13, 2007 | 06:31 AM
Benxrrst's Avatar
Benxrrst
Ok thanks for the info will try and get it done this weekend together with the other stuff its an endless list vibratech mounts, new steering rack....
Old Dec 13, 2007 | 02:02 PM
Red_bull's Avatar
Red_bull
What if you're car first needs to go to a tuner? i probably won't be able to drive because it needs to be set up so i need to do it without moving?? or wont't it be a problem if i rev it to 2500 without set up?
Old Dec 13, 2007 | 02:09 PM
Dragsteer's Avatar
Dragsteer
I think will not do any harm if drive it on 3000 rpm just for cam run in, because you can drive it on higher rpm without boost
Old Dec 13, 2007 | 03:01 PM
Christian and Beccy
#1 in Spelling Club
As above. You'll not be revving it above 3000rpm, so won't be a major problem if its not set up. As long as you haven't changed anything else that would seriously affect fuelling.
Old Dec 13, 2007 | 04:38 PM
Badman38's Avatar
Badman38
any rs turbo with a decent cooling system should not over heat standing still with the revs held at 3000rpm, the cam could be run in stages of five minutes.
sean
Old Dec 13, 2007 | 06:49 PM
Christian and Beccy
#1 in Spelling Club
sean
There's the problem Sean, check out how many posts there have been on this forum alone about over-heating problems and you will know that MOST RS Turbo's do infact have an issue.
Why do it stationary anyway? There's no need, providing you have a quiet road to do it on.
Old Dec 13, 2007 | 07:01 PM
swerv's Avatar
swerv
i done mine in 2, 10 minute stages as said above.
lots of ways of doing things though , but i wouldnt do it on the road just out of preference
Old Dec 15, 2007 | 06:32 PM
Badman38's Avatar
Badman38
sean
but thats the problem christian i think many of as would do the work at home, where there is instant access to a quiet road, alot less hassle doing it stationary if you cant run your car at 3000rpm for twenty minutes then run the cam in stages also look to improve your cooling system because i know the standard rs rad is not man enough.
sean
Old Dec 17, 2007 | 08:58 PM
Moose's Avatar
Moose
what do you do if you have modified the engine completly from a standard setup and need to run the cam in?
i haven't run mine yet
Rich
Old Dec 18, 2007 | 04:04 AM
Badman38's Avatar
Badman38
Rich
on start up DO NOT LET THE CAR IDLE FOR THE FIRST TWENTY MINUTES keep the car above 2500rpm job done.
sean
Old Dec 18, 2007 | 08:22 AM
Benxrrst's Avatar
Benxrrst
Me and a friend finally fiited cam in the freezing conditions last nite started it up and held it @ 2500 rpm took ages to warm up i noticed the engine seemed more responsive too so now its had its 25mins of run in its time to take it for a slow but steady drive around.
Thanks for everyones input
Ben
Ps i have no heating problems its got a brand new alloy rad on
Old Dec 18, 2007 | 10:59 AM
Red_bull's Avatar
Red_bull
Euhh i changed quite alot and also the fuelpump upgrated to a cosworth!
from standard engine to a +- 190 bhp.... so maby run it in by the tuner and let him do the job?
JoeyBoyden
Jan 4, 2024 02:36 PM
RUBY123
Oct 22, 2023 12:04 PM
Danielbetty
Oct 3, 2015 06:01 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
