splutter on boost
Old Sep 21, 2007 | 03:05 PM
sy.rst's Avatar
sy.rst
Default splutter on boost
iv just changed the headgasket on my series 2 rs but when it comes on boost it splutters and wont go anywhere sounds like its got a boost leak but hav checked all boost pipes all seam ok and tight.any idears
Old Sep 21, 2007 | 03:16 PM
Hrsturbo's Avatar
Hrsturbo
check your cam timing and valve clearences if you have solid followers
Old Sep 22, 2007 | 04:51 PM
sy.rst's Avatar
sy.rst
just checked cam timeing its fine,bottem pulley mark on 0 and the pointer on the cam pully lined up wiv the mark on the head.am useing a piper 285t2 cam
Old Sep 22, 2007 | 05:51 PM
gee1599's Avatar
gee1599
spark plug gaps may be or leads ??
Old Sep 23, 2007 | 09:35 AM
sy.rst's Avatar
sy.rst
the plugs and leads are both new
Old Sep 23, 2007 | 10:35 AM
Dragsteer's Avatar
Dragsteer
Have you check fueling ?
Old Sep 23, 2007 | 10:51 AM
Oranoco's Avatar
Oranoco
Has the cam eaten itself? The Pooper cams are well known for it.
How was the car running before the headgasket change
Old Sep 24, 2007 | 10:34 AM
sy.rst's Avatar
sy.rst
it was running fine b4 i changed the gasket,apart from overheating but i fitted the piper cam at the same time as i changed the gasket,it woz a second hand cam it doesnt rattle at all tho,thought it would rattle if the cam woz worn.
Old Sep 24, 2007 | 12:39 PM
Oranoco's Avatar
Oranoco
Did you check, measure the lobes on the cam before fitting?
I would seriously be suspecting the cam about now. Second hand cams really aren't a great idea
Old Sep 24, 2007 | 08:35 PM
project rs's Avatar
project rs
part of your problem is you've got the timing wrong you've put it to standard ford timing and you need to set it to 118 degrees atdc with number 1 inlet fully open had this the other week on a friends rs and now starts and boosts fine. if your not sure how to do this put standard one back in and see how it runs then process of elimination if still no better
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
