depends what route you are going to take. you can either use the hole for the cps sensor if you have one or if you dont you can use a trigger wheel so if you say which route you are taking i will be able to tell you what you need fella
sierra bottom pulley, cam cover (for the cps sensor), sierra alternator and bracket, efi inlet, efi head or adapter plate, frst loom + ecu and sensors(eec co2 pot map sensor etc) escort efi throttle pedal bracket and cable they are the main bits needed just to give you a rough idea fella
contact gup off here he has a spare s1 loom for sale your best off wiring the frst loom into that one instead of butchering your loom and being off the road like i was
