Using 4G63T DSM Turbo Manifolds on your CVH (YEP!)
I thought i'd pass the innovation accross the pond from over here in the states. All you have to do is flip the manifold, create a bracket for bottom row bolts and redrill the top row bolts on the manifold.. and port match the manifold to the head.. the port spacing is the same. Creates a nice top mount manifold.. you can get a cheap DSM stainless turbo header, flip it, port it accordingly, remount your IC plumbing etc, and have a much better flowing setup!
Check here for more info:
http://www.cardomain.com/ride/2218783/2
btw, this is ©Jeffescortlx I cant take credit for his work!
no copyright tho so feel free to try it on one of your RST's!
get one of those nice aftermarket with external wastegates... you'll have to custom do your downpipe tho.. np
example:
http://cgi.ebay.com/ebaymotors/ECLIP...spagenameZWDVW
$80 US + SH
use ebay.com not ebay.co.uk
$80 US + SH
so for about ₤110 total (₤40 for the manifold and ₤70 for postage from US) you can have that stainless steel manifold shown above shipped to your door in the UK... i'd like to see what you peeps can do with that turbo header!!!
more examples for more money:
search link 'eclipse manifold': http://motors.search.ebay.com/eclips...d_W0QQfromZR40
t3's
http://cgi.ebay.com/ebaymotors/ECLIP...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/ECLIP...ayphotohosting
t3's
the evo has a different turbo flange than the eclipse 4g63, otherwise it is the same deal w/ it bolting up to the CVH head.. you just have to cut off that funky mitsu turbo flange and weld on a t3
as far as power increases with the eclipse 4g63 manifold, jeff is about to demonstrate that for us here in the states, so will keep you updated. but should flow better than the rs manifold with the #2 and #3 cylinder collector's
JK12
33
26-04-2021 12:09 PM
Matt Baxter
16-09-2015 08:30 PM
