new problem.........dead s1.....PROBLEM NOW SOLVED
Old Aug 7, 2007 | 09:14 PM
pugo's Avatar
pugo
Default new problem.........dead s1.....PROBLEM NOW SOLVED
ok after my chronic misfire , blowing hoses, overboosting and generally being a 20odd year old ford
i spent the day sorting loads of odd problems out
head gasket had shit itself
numerous hoses had perished
pipe to actuator had a small split in it
then i went to burtons and bought what the guy said was the right plugs for a chipped rs turbo (somebody tell me what they are running)
which i put in and the amplified the original misfire........crap
then i put a set of magnecors on it and it finally settled down...or so i thought lol
it ran well all afternoon................and then as i came round a bend, everything went off, lights, wipers, engine died, clock in the roof, everything....so i rolled to a halt, turned it off and the ignition lights all stayed on ?????? it cranks over but will not fire.......and i have had to disconnect the battery to turn the ignition lights ?? is this a common fault or have i got to trace through the whole loom ????
somebody help me, as this rs turbo lark is starting to piss me off......starting to wish i had stuck with cossies
Pugo
Old Aug 7, 2007 | 09:24 PM
Barry R's Avatar
Barry R
I have never heard of this problem before
could it be the fuse box?
Old Aug 7, 2007 | 10:41 PM
gup's Avatar
gup
could be your ignition barrell at fault fella
Old Aug 8, 2007 | 06:54 AM
pugo's Avatar
pugo
i have no idea at the mo...but if it stays dry then by tonight i should do lol
pugo
Old Aug 8, 2007 | 12:55 PM
pugo's Avatar
pugo
problem solved.......the rad had worn through 3 wires.....2 of them being the amal valve wires
Rod-Tarry
237
Mar 18, 2016 09:13 PM
dms04
Sep 11, 2015 01:57 PM
nick8saff
Aug 16, 2015 05:35 PM
Jim Green
Technical essay Archives
May 27, 2004 09:17 AM
