starting problem when hot
Old Jul 30, 2007 | 08:35 PM
burns's Avatar
burns
Default starting problem when hot
my s2 will start first time for cold and you can turn it off and it will start again however if you leave it to worm up and cut the engine it wont start back up it turns over just doesnt fire it will jump off from a push so you can imagine wats its like in petrol stations help please
any sujestion no matter how daft would be graetfull as i have seen to tryed everything more than once and dont know what i hav missed
Old Jul 30, 2007 | 08:47 PM
J690Turbo's Avatar
J690Turbo
my mate had a similar prob with his s1 the other day and after talking to a few people we were directed to a sensor under the cold start valve, forgot wot it was called had a brown plug, so when we unscrewed it turned out the connection were hanging off, so got another sensor and its been fine since, could b same problem
Old Jul 31, 2007 | 09:15 PM
burns's Avatar
burns
ill hav a look ta
anymore ideas
Old Jul 31, 2007 | 09:49 PM
Barry R's Avatar
Barry R
lazy starter?
Old Jul 31, 2007 | 11:05 PM
SafeChav's Avatar
SafeChav
That won't of been your problem mate, that sensor only controls the cold start valve when the engine is stone cold, it does absolutely nothing when the engine is hot. Its a Thermo Time Switch (TTS) by the way.
I would check to see if your fuel system is retaining pressure. I had this exact symptom on my cabriolet when i first converted it - as you say it was a fucking show up on the petrol station forecourt.
Mine would start after about 4-5 mins of solid cranking
This was because the fuel pressure wasn't being held in the line, you will hear some funny noises from the tank if you have the same fault i expect. And also pressure release when you take the petrol cap off.
Old Aug 1, 2007 | 01:03 PM
CARL B RST's Avatar
CARL B RST
I had the same problem a year or so ago, and replacing the fuel pump relay (purple one up behind the drivers side of the dash) seemed to do the job. worth a try as they're pretty cheap.
used to really get on my tits having to push it away from the pumps!
Old Aug 1, 2007 | 06:18 PM
burns's Avatar
burns
yeah that does happen sometimes with the tank and that mate so how did you fix it cheers
Old Aug 1, 2007 | 07:25 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
starter cables worn, burnt, knackered?
try puttin new uns over the old 1's
Old Aug 1, 2007 | 10:15 PM
mentalasanything's Avatar
mentalasanything
I had this. Mine was a problem with the wiring in the fuse box. Basically to get the headlights working as the realy was shagged, some previous owner had bridged some fuses between eachother in the fuse box, this in turn was fucking up the immobiliser on my toad alarm.
I removed said wires and replaced the relay and I never got the problem after that.
My trick at the time was to start the car with the door open (something was really screwing with the alarm) and it would go ok. Also made the clock reset every time I opened the door!
Check there arent any fuses bridged!
Lee
Old Aug 1, 2007 | 11:36 PM
SafeChav's Avatar
SafeChav
You need to test the fuel pressure in the line. Turn it off for a few minutes and check to see if there is pressure in the line or not.
Old Aug 2, 2007 | 06:56 PM
1.9 xr2 on 40's
st170 breaking
Lee
cool
Old Aug 4, 2007 | 08:38 AM
mentalasanything
Lee
cool
I know And as soon as I took out the wires bridging the headlights to the sidelights it worked fine and has ever since?????!!!!! Something to do with ignition lives I suppose. The LED on the alarm was all screwy too, only going the right colour with the door open etc.
With the clock, Chris, the guy who had it before me used it like a turbo timer, every time he stopped, he'd open the door to reset the clock, wait for the clock to tick up to the desired number of minutes and turn the car off
The electrics on these cars never cease to amaze me.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
