s1
Nothing as long as its 3 door and made after May'83...
Pre May'83 Mk3 shells have a 2 bolt fixing on each front suspension turrett, and are very different to the later shells. Most suspension parts are not interchangable.
I dont know is if a Series 1 has a rear anti roll bar as standard. If they do then a non RS shell wont have the mounting holes on the rear crossmember.
Hope this helps
Hope this helps
S2's arent exactly meaty
Originally Posted by JesseT
post 83 non-RS bodies have the mounting points too.
Another thing that spung to mind, is the open rear quater hinge fixing points...
