best zvh compression ratio
i want to build a new 2.1 zvh turbo with new pistons if i use vauxhall calibra turbo pistons, what will the ratio be, will i need to get them machined down or leave them as they are,and what is the best cam to use piper 285t3 any good,
This ZVH works well.
link to Wul's results <<<<click me>
link to Wul's Spec <<<<click me>
most of the answers you are looking for are within the above posts.
hope that helps
hope that helps
Originally Posted by ZVH,RST
so is 7:5:1 lower compression than 8:2:1 as a lot of people say different, ratios. when it comes to turbo engines,
In my zvh conversion didnt fancy spending £500 on pistons and having to have the block bored so i brought a 1.5mm spacer plate to lower the compression using standard pistons and running just under a bar of boost and it goes like stink and its been like that for near on 15k with no problems.
(touch wood)
(touch wood)
TPM961
15-01-2018 10:50 AM
