Turbo oil feed part
Turbo oil feed part
Hi all,
Can anyone tell me what the part where the oil feed pipe screws onto on the turbo, the "adapter plate" bit that bolts to the turbo (sorry for the descritpion) and where i can get another one from. Mine has the the feed hose welded to the plate, and i have a new feed pipe to put on. Its for T3 off a S2.
Many thanks.
Neil
__________________
Many thanks.
Neil
__________________
They usually screw into the turbo direct.
so remove the plate thats bolted, and get a 1/8 - 1/4 male to male union.
and then you can screw that into the turbo, and oil feed line onto that.
Same as this, but i have a pre turbo oil filter fitted.
Hi mate, i see what you mean, but not sure its what i need. I have the same part that needs to be un bolted from the turbo, but where yours has the threaded union on top of the plate, mine hasnt and the oil feed pipe has been welded to the plate. So i need a replacement plate, so i can screw my new oil feed pipe to it. So can you buy these plates, and and what are they called??
Cheers,
Neil
Cheers,
Neil
Okay here's a pic of what im on about, as you can see the oil feed pipe has been welded on, so i need a new plate with the threaded connection to attach my need feed pipe.
[/img]
[/img]
You need a 1/8 to 1/4 double male union.
then that will screw into your turbo, and a Std rst oil feed line will screw onto that.
Try a hydrolic hoses/fitting store. about £3.
i have them spare. if you pay for it, and the postage.
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
muz
16-08-2015 12:57 PM
