Bleeding Brakes Problem`
Old Apr 23, 2007 | 06:47 PM
BlueFiesta85's Avatar
BlueFiesta85
Default Bleeding Brakes Problem`
ive just fitted up some new copper pipes with goodridge hoses. poured fresh fluid into the system as the old one was completely empty due to the pipes cut. followed the normal procedure bleeding the brakes, starting with pumping the pedal until vacuum is destroyed but i keep getting a psssst sound everytime i push the pedal is this normal?
anyway opened the screw on the drivers side rear by half a turn and pumped the pedal a good 50 times but not getting any fluid coming out the rear. what could be the problem?
currently the engine is not installed so the vacuum pipe is disconnected from the manifold.
help please
cheers
Old Apr 23, 2007 | 08:22 PM
NUTS RuS's Avatar
NUTS RuS
Your bleed method maybe ?
If your not closing off the screw each time it will just suck air back in and then push it out again on the next pres of the pedal
Old Apr 25, 2007 | 09:18 AM
BlueFiesta85
figured out the prob, the load apportioning valves at the rear were not opening up therefore not allowing the fluid to seek through. had to unscrew the two bolts on the bracket and push the spring so that it would open the valve
yatta
May 21, 2016 10:31 PM
markk
Sep 9, 2015 08:11 AM
routemaster
Sep 7, 2015 05:27 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
cossirob
Sep 3, 2015 09:17 PM
