ignition timing
Old Apr 9, 2007 | 04:46 PM
Dragsteer's Avatar
Dragsteer
Default ignition timing
hello
Does somebody knows how much degrees I must set timing on rst (stock engine, no mods, boost is 0.55 bar) ?
Old Apr 9, 2007 | 07:55 PM
JesseT's Avatar
JesseT
12deg with idle revs and map hose disconnected.
Old Apr 10, 2007 | 04:51 PM
Dragsteer's Avatar
Dragsteer
Thanks m8
map hose is hose which goes from inlet plenum (vacuum) to ecu?
Old Apr 10, 2007 | 04:57 PM
antony215's Avatar
antony215
Escort Rs Turbo
Yes
Old Apr 10, 2007 | 06:40 PM
JesseT's Avatar
JesseT
And remember, idle is around 700rpm, not 1000 rpm or so.
Old Apr 10, 2007 | 06:45 PM
Fiecos Dan's Avatar
Fiecos Dan
idle's quoted at 800 to 900 rpm.
Old Apr 10, 2007 | 07:47 PM
JesseT's Avatar
JesseT
Just checked, and 850rpm is what Ford states. Anyhow, at 1000+ a timing error is made very easily. This and the map hose not removed are the two most common timing faults both resulting in too little advance and poor performance. You will be amazed how many of the RSTs I have tuned actually have way too little advance even though the owner says that he has just set it to 12.
Old Apr 10, 2007 | 07:51 PM
Fiecos Dan's Avatar
Fiecos Dan
Also,
i think ford quote slighty less rpm on a S1 than a S2, think its 50 rpm less..
Old Apr 11, 2007 | 04:17 PM
Dragsteer's Avatar
Dragsteer
Thank you all
but what role have knock sensor? isnt he here to advance timing before knocking? or he will do wrong job if I didnt set ignition timing?
Old Apr 11, 2007 | 05:33 PM
JesseT's Avatar
JesseT
I doubt it will never advance the timing beyond the map value. It's just to retard it in the case of knock.
Old Apr 11, 2007 | 06:11 PM
Dragsteer's Avatar
Dragsteer
OK. I will do like JesseT said. thanks
Old Apr 11, 2007 | 06:23 PM
Fiecos Dan's Avatar
Fiecos Dan
As jess said,
the knock sensor on a RST will only retard if it picks up det, and will never advance till det.
Old Apr 12, 2007 | 08:10 AM
Dragsteer's Avatar
Dragsteer
ok. I will go tommorow set ignition on 850 rpm with map hose dissconected. because I never checked ignition timing. and I am sure that mechanics in my country doesnt know that map hose must be dissconected (and hole on plenum blocked?) and doing all on 850 rpm.
Old Apr 12, 2007 | 06:17 PM
djmillsy's Avatar
djmillsy
Fife Radge
why do you disconnect the map hose
Old Apr 13, 2007 | 10:22 AM
JesseT's Avatar
JesseT
Because otherwise the ecu will advance the timing and the 12deg is specified with the hose removed. Simple as that. Failing to remove the hose when setting the advance to 12deg means you're some 6 degrees of and ~15% short in hp.
Old Apr 13, 2007 | 02:20 PM
djmillsy's Avatar
djmillsy
Fife Radge
just wnider cause mine was just done and its 0 degres so is it 12 deg on the crank and 0 on the cam
Old Apr 13, 2007 | 09:09 PM
Rick's Avatar
Rick
Different ECU's have different advance curves too. A more accurate way is to apply pressure to the ECU map sensor, and set to 14 degrees at 4000rpm. I do neither, and tune it by ear on the road.
Old Jun 28, 2007 | 09:44 PM
Dragsteer's Avatar
Dragsteer
just one thing, After setting rpm idle at 850, and dissconecting map hose , must I block map hose with somethnig? I mean block hole on inlet plenum and hole on hose which goes to ECu? and off course , set 12 degrees...
Thanks , hope non ford mechanic will know do that with my help
Old Jun 28, 2007 | 10:12 PM
Fiecos Dan's Avatar
Fiecos Dan
Yes best block it, so theres no vacum leak, use a small bolt.
Old Jun 28, 2007 | 10:14 PM
Dragsteer's Avatar
Dragsteer
Now I have complete giude for i.t.
Thanks mate
van_dogg_pavvy
Mar 3, 2016 09:30 AM
xrmalin
Sep 13, 2015 06:52 PM
hopper350
Sep 4, 2015 12:53 AM
Zoggon
Aug 10, 2015 10:39 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
