HELP !!!!! Starting problems.....
Old Mar 5, 2007 | 06:01 PM
MattyRST's Avatar
MattyRST
Default HELP !!!!! Starting problems.....
I will try and explain the best i can here goes.......If i leave the car for a week or so the starts fine, when i take it out and stop for petrol and turn it off it will start again no problems but if i stop and turn it off and leave it 20 mins or so and come to start it again it will not start, it turns over but will not fire up. I know it could be anything but has anyone had this problem ??
Ive changed plugs, leads, dizzy, rotor arm and the car has a turbo timer on which works fine. Im gonna change the ignition coil next...
Please help me as its driving me mad.............
Old Mar 5, 2007 | 06:10 PM
turboloon's Avatar
turboloon
like you say could be coil or maybe a duff altenator safe chav or rick would be the guys for these kinnda problems
Old Mar 5, 2007 | 06:14 PM
MattyRST's Avatar
MattyRST
Cheers turboloon
Old Mar 6, 2007 | 10:35 PM
MattyRST's Avatar
MattyRST
Has anybody had this problem ?????
Old Mar 8, 2007 | 08:06 AM
MattyRST's Avatar
MattyRST
Anybody ???
Old Mar 8, 2007 | 08:19 AM
SaqsS2turbo's Avatar
SaqsS2turbo
dudee im geting the same problem and ive got a group A coil its bugging me
Old Mar 8, 2007 | 10:57 AM
MattyRST's Avatar
MattyRST
Could it be the metering head then ? SaqsS2turbo Ive got a spare one at home but it doesnt have the screw that you turn to set the CO mixture, the bit that stands up behind where a filter would go. I was gonna try and make one good one out of the two
Old Mar 8, 2007 | 01:29 PM
SaqsS2turbo
oooooo sweeet can do with one dude pm me the details
Old Mar 8, 2007 | 02:05 PM
SaqsS2turbo
i think it is the metering head the floats pin leaked on my last one a hell of a lot
Old Mar 8, 2007 | 02:47 PM
SafeChav's Avatar
SafeChav
i'd almost guarantee the one way valve in the pump is fucked, either that or you have a leak somewhere on the main fuel line which is allowing the pressure to drop off
Old Mar 8, 2007 | 02:53 PM
SaqsS2turbo
in that case i just figured my problem out
Old Mar 8, 2007 | 03:04 PM
MattyRST's Avatar
MattyRST
SafeChav would that explain why it will start if i leave it a week, but if i try to start it after 20mins it wont start. Yet it runs fine when i drive it
Old Mar 8, 2007 | 03:07 PM
SaqsS2turbo
ok accoring to matty my problem ent solved
Old Mar 8, 2007 | 03:14 PM
MattyRST's Avatar
MattyRST
SaqsS2turbo are you having the same problems as me then mate ??
Old Mar 8, 2007 | 03:16 PM
SaqsS2turbo
yup sure am loll its a basterd
Old Mar 8, 2007 | 03:18 PM
MattyRST's Avatar
MattyRST
Can SafeChav conform that the problem is the one way valve pump is fucked thats why we are having the problems that ive stated
Old Mar 8, 2007 | 03:22 PM
SaqsS2turbo
were is the one way valve in the pump?
Old Mar 8, 2007 | 03:46 PM
mentalasanything's Avatar
mentalasanything
My starting problems were solved when I replaced the Injector O-rings and collets. I found these need to fit and seal 100% or it will cause no end of problems starting hot or cold.
The other thing is that wires in the fuse box that have been patched in between fuses, these made the immobiliser play up again, with various symptoms.
Hope this helps
Lee
Old Mar 8, 2007 | 07:44 PM
MattyRST's Avatar
MattyRST
Cheers mentalasanything ill check my wires to the fuse box and fuses, are the injector seals and collets expensive to buy and are they easy to fit ??
Old Mar 8, 2007 | 08:06 PM
SafeChav's Avatar
SafeChav
I can't guarantee your fault, but i know mine had a very similar fault. It wouldnt start perfect from cold, but you didnt have to crank it over for 5 minutes solid like you did when it was hot and you switched off to put petrol in (which got very embarasing on a daily basis )
Check for pressure, leave it overnight and before you even put the key in the ignition push the flap on the metering head down and it should rise back smoothly, if it springs back then it has lost pressure.
As a yard stick, after that prime the pump a few times and repeat the test.......thats the easiest way
Old Mar 8, 2007 | 08:13 PM
MattyRST's Avatar
MattyRST
Cheers SafeChav I shall try what you have suggested mate
Old Mar 8, 2007 | 08:14 PM
SafeChav's Avatar
SafeChav
Its certainly worth a try, won't cost you anything
Old Mar 10, 2007 | 09:15 AM
SaqsS2turbo
right i done all this and it is the injector seals got damn little things lol car starts perfect now
Old Mar 10, 2007 | 06:55 PM
MattyRST's Avatar
MattyRST
I left mine for 30 mins tops again 2day went to move it and it wouldnt start, took the filter off pressed the flap and it sprang back didnt come back up smooth, does this mean i need a new metering head ?
Old Mar 10, 2007 | 06:57 PM
MattyRST's Avatar
MattyRST
The car has an auto speacialist fuel pump if this helps or is it the metering head ?
Old Mar 10, 2007 | 08:38 PM
SafeChav's Avatar
SafeChav
If it sprang back instantly and didnt rise smoothly you are losing the fuel pressure as i suggested.
If there is no leaks on the main fuel line try a new one way valve. If you sit in the car after switch off you will probably hear all kinds of noises from the tank where the fuel pressure is being released back into the tank
Old Mar 10, 2007 | 10:21 PM
Dragsteer's Avatar
Dragsteer
my mechanics said that "he doing something on metering head" and how car is starting wery good. he said that I must rebild metering head. before that, I have same problem- wont start when hot
Old Mar 11, 2007 | 08:41 AM
MattyRST's Avatar
MattyRST
SafeChav Where is the one way valve on the metering head as i have a spare one and is it an easy job to do ? Could it be possible that im losing pressure through the injector seals like SaqsS2turbo ?
SaqsS2turbo how much for new injector seals and where can i get a set from ?
[/b]
Old Mar 11, 2007 | 01:30 PM
SafeChav's Avatar
SafeChav
The valve is screwed ino the fuel pump, its not on the metering head.
The injector seals present an air leak, not the same thing The fuel pressure is held in the main fuel line only when the car is switched off.
If it was injectors seals you would probably hear the air being drawn in, very rare to happen being honest.
Old Mar 11, 2007 | 01:35 PM
MattyRST's Avatar
MattyRST
I put a brand new fuel pump on it less than 2 months ago, an auto specailists cossie fuel pump for a S2
Old Mar 11, 2007 | 01:40 PM
SafeChav's Avatar
SafeChav
Doesnt mean to say the valve isn't faulty. Don't get me wrong though, it simply unscrews
You haven't got to buy a new pump or anything like that!
Old Mar 11, 2007 | 01:42 PM
MattyRST's Avatar
MattyRST
If it is that valve in the pump how do i fix it then ?
Old Mar 11, 2007 | 02:24 PM
SafeChav's Avatar
SafeChav
Well firstly i'd whip it off and see if you can blow through it! Mine was stuck open so i was able to blow through it
Old Mar 11, 2007 | 02:29 PM
MattyRST's Avatar
MattyRST
Im no mechanical If im not getting pressure is it coz the valve is stuck open or shut ? Can it be fixed if its open/closed
Old Mar 11, 2007 | 02:33 PM
SafeChav's Avatar
SafeChav
The valve should close up to hold the pressure in the line, if they stick open all the pressure gets forced back into the tank when you switch off.
Also means your pump is getting more knackered each time it primes up after a long switch off.
Old Mar 11, 2007 | 08:27 PM
MattyRST's Avatar
MattyRST
Ive had a look in the haynes manual and a friend has advised me that i should change the fuel pressure regulator on the inside of the fuel distrubutor, i have a spare one at home so i may try that
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
