My S1 problem. pls read.
Around Apil last year I changed the Second Injector and injector line after the connecting bit on the banjo broke.
http://smg.photobucket.com/albums/v4...=rst2010-1.jpg
i got the injector of ebay...cheap with the red pipe.
Could the injector be faulty affecting Cylinder 3?? and causing excessive fuel consumption??
or would this problem be the metering head?
Why not take the car to a decent tuner get them to check the injectors out and tune the car. Then take it from there when the tuner tels you your metering heads fucked i'd trust there judgment, but take it somewhere thats reputable and know about rst's
could be fella is thier loads of of blue black smoke coming out also does it smell of petrol inside the engine bay
have you checked your plugs to c if the tips are wet or coloured differantly
does the a/f meter flap go down smootly with a bit of resistance
Grey Mk4 Early XR3I
mine used a stupid amount of petrol (mines not an rs but im sure its similar) and had a very small splitt one of the fuel hose's causing ti to drink alot mroe fuel (car went faster i might add) then got it sorted by replacing the fuel lines
yer that makes sense mine isnt that bad and its only when i boost it really hard when leaving it all night in my garage it doesnt leak at all
Grey Mk4 Early XR3I
its an injection it wont leak while its turned off mate turn the engine on and get it up on a set of ramps ull probably notice it dribbling on to the floor
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
cozzy jeff
14-08-2015 05:46 PM
