s2 grs intercooler fitting question
Old Jan 14, 2007 | 03:56 PM
rsdan's Avatar
rsdan
Default s2 grs intercooler fitting question
Just bought a front mount grs intercooler with single 10" kenlow fan for my series 2 rst, i have removed the bumper today to fit the cooler with the intention of fitting the fan in front of the radiator and then the cooler in front, i have so far fitted the fan to the radiator, now started to mount the intercooler but it is fouling the bumper in several places, would just like to no where people cut there bumpers and if they cut the front lip of off the cross member, hopefully someone can shed some light on the problem as i am desperate to fit the cooler... also any pics would be great..
Old Jan 14, 2007 | 04:15 PM
SafeChav's Avatar
SafeChav
Dont think the cross member usually gets trimmed, but the bumpers are common normal to need to trimming.
Oh, and its probably best i tell you while you haven't yet fitted it, your guna need 2 fans unless you want it overheating
Old Jan 14, 2007 | 04:44 PM
rsdan's Avatar
rsdan
Default intercooler
surely it shouldnt be a problem with 1 fan there are many around running 1 fan, and you only get one from standard, could understand it being a problem if the fan was in front of the intercooler, do ya have any pics of 1 being fitted? or fitted with the bumper off
Old Jan 14, 2007 | 04:50 PM
SafeChav's Avatar
SafeChav
Try it and see mate, ive read a lot though where people only have one fan and get overheating problems
You've got to remember the intercooler is a MAJOR restriction of air flow to the radiator, and the fan can't draw much fresh air in.
I don't have any pictures mate sorry Do a search theres lots of threads about that had pictures
Old Jan 14, 2007 | 05:33 PM
addiction's Avatar
addiction
you shouldnt have to cut any of the bumper if it's a GRS EVO 4 or 5.
did you buy it new? and if so did you tell Graham you was putting the fans between the rad and cooler? cos he puts the brackets in different places depending on how you fit it.
you are probably gonna need 2 fans aswell
Old Jan 14, 2007 | 08:29 PM
grsford's Avatar
grsford
i fitted an evo 5 intercooler to mine a little while back. what bumper is on you car? in the kit you should have got a fitting kit which graham makes up to move your rad back?if so you will need to purchace a shorter alternator belt as will. personaly i had to shave a little off the top of the bumper but im sure it can be fitted without bumper mods. oh and two fans would be advisable and dont forget to put a little bend in the bonnet catch arm so it dosen`t foul the cooler i will post pictures after work tommorw if you want
Old Jan 14, 2007 | 09:11 PM
rsdan's Avatar
rsdan
that wud be ideal if u cud plz mate.
Old Jan 14, 2007 | 09:13 PM
rsdan's Avatar
rsdan
yes i did tell graham that. ive seen loads off s2 wiv grs intercoolers and only usin 1 fan wen its behind the cooler
Old Jan 14, 2007 | 09:26 PM
grsford's Avatar
grsford
you will def need an overide swith on the fan and you will have to put it on really early in traffic normal driving it will be fine, but two fans would be alot better, so one fan should be ok as long as your really carefull
Old Jan 14, 2007 | 09:54 PM
rstdave's Avatar
rstdave
Fitted one fan to mine between the rad and the cooler and had concerns with the cooling in the summer, would be alright at this time of the year i spose. Main problem is that with one fan it takes such a long time to actually knock the heat out when u stop.....and the kenlowe fans are nothin like as effective as the standard ford one! Fitted 2 fans and no complaints now, override switch as well.
Old Jan 15, 2007 | 11:20 PM
rsdan's Avatar
rsdan
I will see how i get on wiv 1 fan but i will prob get another 1 just b4 the summer starts. mines a 10", will 2 of them fit or will i ave to get smallier 1s
Old Jan 15, 2007 | 11:26 PM
addiction's Avatar
addiction
i went with 1 fan to start with, then came the summer and i soon needed the 2nd!
2 x 10 inch kenlowe's will fit but you will have to move the rad back and get a shorter fan belt
Old Jan 15, 2007 | 11:29 PM
DanRSturbo's Avatar
DanRSturbo
You will deffo need 2 x fan's in the summer, I personally would fit it now whilst you have it all apart, rather then wait for a hot day to piss about taking the bumper and the cooler out again
Old Jan 15, 2007 | 11:42 PM
rsdan's Avatar
rsdan
i see ur point mate but ive got a holiday to pay for so cant afford to buy another one just yet.
rsdan's Avatar
rsdan
thanks for all the advise guys
Old Jan 16, 2007 | 01:53 PM
SafeChav's Avatar
SafeChav
rsdan just make sure you get an override switch in the car, its easy to do.
Ive got a diagram i made for someone else on here if you're not sure how to do it
Old Jan 16, 2007 | 05:24 PM
ivorbiggun's Avatar
ivorbiggun
Put the fan where it's supposed to sit. IE in front of the rad and behind the I/C that way even in August in traffic you'll have no problems.
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
Red_bull
Aug 25, 2015 06:27 PM
RsS2daz
Aug 14, 2015 05:26 AM
Perfmr2
Aug 6, 2015 07:30 AM
