hp cvh oil pump mod ?
Custom
i remember a few years back ht racing showed in a mag how to make a standard cvh oil pump into a high pressure one anyone know how to do it ?
dont you want a high flow pump as all a high pressure one does is flow the oil quicker so it doesnt cool as well. a high flow one cools a bigger amount of oil. or am i talking bollocks
what sort of oil pressure should you see at idle when warm?
reason i ask is i have a high pressure oil pump and i wondered if my oil pressure is too high...?
i have a huge oil coller from a rotary turbo
i simply took about 10mm off an old spring and upped my pressure by about a bar by adding it in , works alright
have to be careful here , too much pressure will lead to the seals on the turbo popping
better higher than lower!
JK12
33
26-04-2021 12:09 PM
jonfoc
16
11-09-2018 05:35 PM
