Running Problem
Old Oct 2, 2006 | 10:41 PM
Escort.Cosworth's Avatar
Escort.Cosworth
Default Running Problem
Hi not long just put a escort rs turbo engine into a mk5 escort xr3i picked the car up a few day's ago from getting wired up and on the way home put the foot down a litte but car would hold back and wouldnt go over 70+mph
Could it be running rich with it still running the xr3i fuel pump? car runs sound and boost's ok till you get upto about the 70+ mph mark then get the boost problems and not wanting to go over 70mph
CheeRS
Old Oct 2, 2006 | 10:44 PM
HORNETS7's Avatar
HORNETS7
what boost r u running?
sounds like it could be boost related or a sensor that is retarding the ignition!
Old Oct 2, 2006 | 10:45 PM
Šhatter Box's Avatar
Šhatter Box
get it set up or better take it all out and go efi job done
Old Oct 2, 2006 | 10:55 PM
Escort.Cosworth
Would love to go EFI but cant at the moment have spend so much on the car the last few months
HORNETS7: Err boost Not sure what boost the cars running, Havent had the time to get a boost gauge yet but will be next on list
The car run's spot on under 70/80mph so cant see it been a boost problem but could be wrong?
Old Oct 2, 2006 | 11:02 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
I wouldn't run it on the 3i pump for much longer tbh mate, won't give you the right fuel pressure.
Old Oct 2, 2006 | 11:12 PM
Escort.Cosworth
Put the car away in the garage for the now as i didnt want to run it with that problem above . On the hunt for a fuel pump at the moment.. what will be the best to get? just a standard rst one?
Old Oct 2, 2006 | 11:29 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Yeah std will be fine, could go for Grp A if you come across one
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
