Indicator Problem
Old Aug 23, 2004 | 06:50 PM
adamS2RST's Avatar
adamS2RST
Default Indicator Problem
OK, out earlier in the car and coming to a round about my indicator was on and then just sudderenly stopped. I took the roundabout and pulled over, tried left and right not working, put hazards on and the hazard light just stayed on but didnt flick on and off. put lights on, ok they still work fine. have replaced fuse and still doing it on and off, sometimes fine and odd occasion it will do it, never seen this before, has anyone else? what else could it be?
Any advise welcome!
CheeRS
Adam
Old Aug 23, 2004 | 06:54 PM
dickie's Avatar
dickie
have you tryed the flasher relay??
think its on the indicator switch under the black trim on your steering column
Old Aug 23, 2004 | 08:21 PM
ballin's Avatar
ballin
aye mate as dickie said check the relay
Old Aug 23, 2004 | 09:22 PM
adamS2RST's Avatar
adamS2RST
What is the likely cause for it's failure Is it likely this is the problem? And would the symptoms be it working and not working?
Old Aug 24, 2004 | 12:29 AM
SS1's Avatar
SS1
this happened on my sapphire ..but clicking hazzard light switch on top of the
Steering Column cured it ..
took off steering wheel there is a black plastic ring on the Column shaft
behind the wheel its got a little cam like key sticking out
this had snapped off..
best news only 75 pence from ford dealership
hope this helps ya.
Old Aug 24, 2004 | 12:35 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Adam, had EXACTLY the same prob on my S1 when i was checkin lights for MOT.......it was a red or Black large fuse/relay in the fuse box, i'd knocked it out slightly, but if ures is fecked cld do the same thing! i checked everyhing under the dash b4 i noticed it wasnt in proper, took me ages
Old Aug 24, 2004 | 06:48 AM
adamS2RST's Avatar
adamS2RST
CheeRS lads, best get this looked at, MOT is next month!
Old Aug 24, 2004 | 06:06 PM
vroooom ptssssh
It Wasnt Me!
well fix it then u monkey!!!!! ive told u what it probably is!
Old Aug 24, 2004 | 06:58 PM
adamS2RST's Avatar
adamS2RST
Will have a look sometime, when I can be aRSed!
Old Sep 6, 2004 | 12:59 PM
adamS2RST's Avatar
adamS2RST
Am now going to check this tonight, lol as I have nothing now! LOL
Old Sep 6, 2004 | 07:07 PM
adamS2RST's Avatar
adamS2RST
Sorted CheeRS lads. But 10/10 and a gold star go to Dickie I had a spare indicator stalk and swapped over the relays, all fine now (He says) na, seems to be working all the time now, and sounds different? Sounds lot better
Adam
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
