wiring loom
ive got a 90spec xr3i efi to take the bits off to do an efi conversion on my s2. ive started taking the loom out from the passenger side from the edis module right round the front including the headlight wiring.
now as ive got to the fuse box im stuck. how do i get all the wiring out? do i take the hole fuse box out and unplug the wiring that goes up the back of the dash? ive had a look onder it and it looks like the whole loom under the dash comes with it
also ive seen pics of frst looms and all the headlight and indicator wiring doesnt look like its on it. am i takin the wrong parts?
had a look on rsbible and hes got a pic of a frst loom and theres none of that wiring and no fuse box in loom. does it come apart before the fusebox.
thanks for any help
thanks for any help
pull the fues box out an unbolt the bottom part of it...[the plastis carrier]umplug all in the car and take the loom out the engine bay side as if your draging it out of car
thanks for any help![Top](https://passionford.com/forum/images/smilies/smile011.gif)
thanks for any help
murdoch1.7zs
the fun you're going to have..........
As Ian says, you gota gut the inside of the car, unplug everything, and it will all lift out of the hole the fuse box lives over
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
thanks for the help
yeah this is goin to be fun.
need to get my alarm taken out then put back in and thats going to cost a fortune. i was hoping it would go that far up
focus rs 1672
thanks for the help
SAFECHAV u havent seen this alarm
the guy that fixed my windows when i got it was a clifford fitter a few years ago and he had a nightmare of a time trying to find the full closure box.
the thing with it is it looks like bits have been added on over the years into it so theres control boxes of the alarm all across the dash.
i went to see him to ask if he could take it out and put it back in and he said no chance
Wimps!!
![Raz](https://passionford.com/forum/images/smilies/tongue.gif)
I'd give it a go, but then.....i'll try anything
do you have to change the entire loom to go efi, or can you not just unplug the ecu's and swap the efi ecu in and all the other engine side of the loom just run off that?
Before fiesta's, looms were one solid piece
Its all seperate unpluggable looms now
So can you use part of the fezzy loom on an escort to run efi. ive been told it envolves cutting the erst loom down and wireing the fezzy one into the engine side.
Originally Posted by krisberic
So can you use part of the fezzy loom on an escort to run efi. ive been told it envolves cutting the erst loom down and wireing the fezzy one into the engine side. ![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
is it much effort to do, how many wires and what ones would need doing
?can you make it look tidy, ie factory and is re wiring difficult,(ive never done electrics!!)
It's not THAT hard, theres about 7 or 8 wires IIRC. BUT, you've also got to wire in the fuel pump relay within the car, aswell as the injection module relay.
You can make anything look proper with a bit of time and care, have a look at this and see if you can figure out what loom it is
![](https://i27.photobucket.com/albums/c163/Safechav/P1010064.jpg)
![](https://i27.photobucket.com/albums/c163/Safechav/P1010066.jpg)
looks like my loom, I spliced into the ERST loom, zip tied up all the original bits and bobs in the engine bay and hid them as well.
The relays aren't that hard to do in side the car either
Mark RS
12-10-2015 06:01 AM
muz
30-09-2015 08:29 AM
