REAR DISK CONVERSION
HI, CAN ANYBODY HELP ME?
I AM PLANNING TO DO A REAR DISK CONVERSION ON MY S2 RS.
WHAT PARTS WILL I NEED AND HOW MUCH IS THIS ROUGHLY GONNA COST? MY DAD IS A MECHANIC SO ITS JUST THE PARTS THAT ARE GONNA COST. ALSO I HEARD U CAN PUT COSSIE BRAKES ON THE FRONT. IS THIS TRUE? AND WHATS INVOLVED. MANY THANKS
Rear brakes need:
2wd Cossie disks and calipers
Con version Bracket
RS2000 handbrake Cable!
Cost, i say around £250, depends on where you get all the bits from etc, etc
Yes you can put cossie brakes on front need 2wd cossie disks and 4wd Calipers, or get a bracket and use the rs calipers!!
Con version Bracket
You will also need a bias valve or 2. You will unbalance your brakes set up and will have problems with the rear brakes locking up.
A RST does not need rear discs!!
Don't ask - I don't know
As said - 2wd front discs, 4wd calipers. Go straight on, and will fit under standard rims (just) but you won't be able to run stick on weights on the inside of the rim - it's that tight but they do go on.
Rears - as said above. And they all bolt straight up, just make sure you get the brackets to mount the calipers on the rear hubs.
when i've braked the back end starts to whip out at high speed, was told rear discs cure this problem as it is due to one drum catching before the other, surely it is worth rear discs for this alone as well as the looks.
My cabby turbo has a burton power rear disc conversion, its improved the stopping power tenfold but still locks up under very heavy braking and the rear end trys to meet the front end SCARY! Ands thats with an ARP bias valve.Need to do some tweeking me thinks! Would recomend the burton power kit though, comes with every thing u need in one box. Only thing u need to order separate are the bolts that secure the caliper brackets to the the stub axel. The heads are mechined down so they dont fowl the back of the hub.
