Who got or done a CVH/Duratec conversion?
should be good!
Hi guys, I have started a conversion using my RS turbo CVH and a brand new 2.0l RS Duratec short motor. I am interested in any info anyone might have. I am looking to get it up and running for Trax.
should be good!
Well I have got the block at work now so I can pick away at the build.
I have cut a large hole in the side of it for the water pump, got some WRC Cosworth rods from Jamsport, just calculating the compression ratio! Looks like I will have to take several mm of the head as the Focus RS pistons have a large dish in them. Just thinking where to put the oil drain and breather and what to do with the extra holes already in the block?
It looks to have quite trick pistons, the standard rods were a bit thin and the crank looks strong.
should be good!
I thought that to but the early ones were belt driven. This one has a ticket on to say that it was built in 2004! Aparently there are only 7 Focus RS short motors left from Ford. The build is a bit of suck it and see.
should be good!
Mr Oddkid I understand your point of view, and for a time I was of that same opinion (optimise the standard kit with a proper set up) but over the years I have also relised that it will only take so far.
I work for a company that always strives to be the best, so some of that work ethos gets transfered to my car.
I am a race and test mechanic for the McLaren F1 team.
Your coment of 250bhp is somewhat shy of my predictions.
mk3ste
17-10-2021 10:09 AM
Johnny Knoxville
30-09-2015 07:21 AM
SMILER258
28-09-2015 09:04 AM
