boost controller
Old Aug 17, 2006 | 08:26 PM
xrchris's Avatar
xrchris
Default boost controller
looking to get a chip soon to allow more boost so lookin for a boost controller to sort it out. any recomendations for a good one to get? would like a digital one but thinking its best to start with a manual controller to get me started.
also to run more than the standard 7psi will i need to get a -31 actuator?
cheers chris
Old Aug 17, 2006 | 09:01 PM
notSteveS2's Avatar
notSteveS2
u need a -31 geezer....
absolutely nothin wrong with usin ur amal that they cum with standard!
Old Aug 17, 2006 | 09:15 PM
xrchris's Avatar
xrchris
cool i'll purchase one soon then, the car is running a fiesta turbo efi engine etc with a t3. so i can just adjust the boost pressure on the actuator rod of the -31? is there a set limit that the amal valve can handle?
cheers chris
Old Aug 17, 2006 | 09:29 PM
notSteveS2's Avatar
notSteveS2
best thing to do is set the actuator to a half moon mate....
then pull the arm over the pin...
then u got little white/black jets in the amal valve.... i think they r in the (A) atmosphere pipe and in the (C) compressor pipe.
u need to make the whole bigger in the atmosphere jet and/or smaller to the compressor jet... best to get it done by a tuner in my opinion tho matey...
Old Aug 17, 2006 | 09:37 PM
xrchris's Avatar
xrchris
ahh c, my mate used to work for a reputable tunging firm so a call to him could be in order.
or remove the amal valve and fit a manual controller. need to weigh up the options
Old Aug 17, 2006 | 09:41 PM
notSteveS2's Avatar
notSteveS2
personally i do not agree with usin bleedvalves if thats wot u r referrin to... althought there will b 100's of ppl who will say their cars r fine usin them...
but its not hard nor expensive to use ur amal valve to control it and is wot the car was usin from day 1...
Air injectors or like a HKS/Blitz boost controller will b best to use if money not issue..
Old Aug 17, 2006 | 10:41 PM
xrchris's Avatar
xrchris
if i can get hold of an avcr or the like for a good price i'd fit one of them as its another gadget lol.
i'll look into the amal valve thing though, never knew about changing the size of inlet/outlet for psi
Old Aug 17, 2006 | 10:43 PM
notSteveS2's Avatar
notSteveS2
yep
its piss easy... u pull the jet out... drill it bigger...
or get a blank 1 and start the drilklin from scratch etc...
Old Aug 18, 2006 | 03:48 PM
rstdave's Avatar
rstdave
Got a greddy electronic boost controller on mine now, money well spent imo, no more fuckin about with bleed valves or amal valves. Just set the boost u want and it holds the same boost throughout the gears....good for makin small adjustments to the boost pressure as well
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
