ofac should i get it to convert my s2 over from mfi?
found an ofac system loom and all ecus and edis and stuff, but is this the better one or is ofab better. can get it all for a good price and been told to convert my series two is very simple.thinking about getting it now so i can do it in my spare time at uni.
any advice please chaps
Best mod i eva done on mine, but my mfi was playing up
mine never started on the key when cold, i had a massive flat spot too with mfi (poss knock sensor i duno)
all sorted now im on efi plus added bonus of the chatter
is it a case of unplug mfi ecu. Plug in ofab/c ecu then plug the engine loom into that side and then jsut connect all the wires to the various bits. what did you have to do?
O and what is that sensor by the gearbox/flywheel???? just bought an frst block and has the whole for it but i want to get the sensor in there now and then can convert to efi when i have all the bits so i dont have to take anything major like engine or box out.
if ur keeping ur escort mfi head then will need to use a mfi to efi inlet adapter plate as i asume you know you use a efi inlet for the conversion, if u decide to use a fezzy head then the efi inlet will fit no probs
www.rsbible.co.uk its all here mate
kwl,didnt sound half as bad(wiring)when i was showed in a brief few mins. Does anyone have a cps for sale?
does the flywheel have loads of square holes on the inside then one longer rectangle or is that just a normal flywheel?
hi im converting me escort to efi but what do i do about the hole where the distibuter sits does this have to have a plate put over it or what?
is it just a case of tapping and drilling the power pack on to the side of the head then as i have a daddy head and i dont wanna throw it away
also does any 1 know how to tell the differance between 0fac and 0fab as i have a loom in the garage and doont know which one it is i also need a map sensor and ecu 4 it if any 1 got 1 for sale
ive used a escort head on mine, the coil pack fits onto a metal bracket then to bracket goes on the head with holes that line up already there 4 u, no drilling required
diff between ofac and ofab r the map sensors, think ofab map senor is better and can handle more boost
burton-power sell those dizzy blanking plates
