RST CVH gearbox bolts Q's help
It Wasnt Me!
Which way do they go in?
from block - gearbox
or
gearbox - block?
how many are their?
The plate that covers the bottom of the clutch, can this be put on when engine and box are mated and starter is on?
Also, the battery earth, that comes from starter? thick wire, got the plastic sleeve on it and the eyelet thing that a bolt goes through to hold it to the block or something, which bolt hole does it go through? and will it be ok to bolt to the gearox using one of the gearbox bolts?
thanks in advance
or
gearbox - block?
how many are their?
thanks in advance
It Wasnt Me!
it's pitch black !!!
come on someone must know what way the bolts go and where the earth wire bolts too atleast?
Alex - what bolts go where? ive prob got mine fitted wrong and wouldnt mind knowing
lords!
lords!
u got two small onces top of gear box then 2 longer onces on back of block then 1 long one at front where earth stap for batery goes and other at the front then 2 small bolts for diry shield for fly wheel
Alex - cheers More use than that slabberchav cunt
so all the bolts go from box - block apart from the dirt shield ones? or?
You won't mind if i cut that microcat transfer on msn then?
Re: RST CVH gearbox bolts Q's help
or
gearbox - block?
how many are their?
thanks in advance
or
gearbox - block?
how many are their?
thanks in advance
the 2 bolts on the top (under dizzy) go gearbox to engine
the 4 other bolts go engine to gearbox.
the plate can indeed be put on when starter engine and gearbox are all mated together.
the starter motor is held on by 3 bolts, the battery earth strap thing bolts onto the top bolt of the starter motor bolts.
or
gearbox - block?
how many are their?
thanks in advance
or
gearbox - block?
how many are their?
thanks in advance
Do you know what size the bolt heads are pmsl
im a specialist in this department now lol
oh and 13mm
oh and 13mm
Im sure you mentioned something about a special tool needed to remove them.......grips or something like that
my specialist tool was a Junior Hacksaw
took me 20 mins of solid sawing to cut the head off it
the bolts are all 13mm except the middle bolt that holds the plate on which is 15mm
the hammer did come in use for bashing the smaller socket on the disintegrated bolt head lol
the plate that covers the lower part of the flywheel/clutch.
Originally Posted by HORNETS7
i meant the shit plate on sump part but yeah they are 13mm head m10 threads !
JK12
33
26-04-2021 12:09 PM
TPM961
15-01-2018 10:50 AM
