confused?? petrol pump
this is the one i took of my S1
http://img.photobucket.com/albums/v4...dt5/s1pump.jpg
this is the replacement i was given....but it dont fit the pos and neg wires.
went to lucas for a pump and they had this one as the s1 pump aswell.
Is it a S1 pump??? cos i cant fit the bugger.
[img][/img]
[img][/img]
You may need to change the terminals for ring terminals. The standard pumps have special ford terminals, so maybe the plugs are hard to obtain and were changed for a reason.....?
Ford was the only manufacturer that used the plugs. This is a fuel pump out of a Audi/VW/Porsche/Mercedes etc. with K-Jetronic and screwed. Just change your plugs and this will work fine!
Re: confused?? petrol pump
[img][/img]
[img][/img]
i sorted it newton.......i had to change the wiring to get it on, the one i had was the standard one, your one was the upgrade.
works spot on bud
works spot on bud
